Results 1 to 5 of 5
Thread: 32 and 64 bit
    Jun 2011
    17
    32 and 64 bit
    Hey guys I have been looking at buy a new computer and have been seeing a lot of stuff about 64 bit and 32 bit computer. I was just wondering what the difference is. Thanks
    Jan 2003
    Milwaukee, WI
    7,657
    The main difference is the ability to use more than 3 gigs of ram/memory..
    Nowadays there is NO good argument for using 32bit over 64 bit.
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    Being able to use more than 3.5 gigs of RAM is also depended on whether your mother board supports PAE (Physical address extension). So, if you have a 32 bit OS you could run more than 3.5 gigs of RAM. Physical Address Extension - Wikipedia, the free encyclopedia
    Minnesota
    17,433
    Microsoft Windows implements PAE if booted with the appropriate option, but current 32-bit desktop editions enforce the physical address space within 4GB even in PAE mode. According to Geoff Chappell, Microsoft limits 32-bit versions of Windows to 4GB due to a licensing restriction,and Microsoft Technical Fellow Mark Russinovich says that some drivers were found to be unstable when encountering physical addresses above 4GB. Unofficial kernel patches for Windows Vista and Windows 7 32-bit are available that break this enforced limitation, though the stability is not guaranteed.
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    I'll have to find one of those "unofficial kernel patches."
  1. Migrating Win 2003 32-bit to 2008 64-bit
    By MTAtech in forum Applications and Operating Systems
    Last Post: September 30th, 2009, 08:53 PM
  2. Problem with 32 bit PHP on windows server 2003 64 bit edition
    By TinMan486 in forum Webmastering and Programming
    Last Post: August 19th, 2008, 10:04 AM
  3. Confused about 256-Bit vs 128-Bit Memory Interfaces
    By Player_13 in forum Graphics Cards and Displays
    Last Post: July 10th, 2007, 11:38 AM
  4. Windows 9x question about 32-bit and 16-bit software installation
    By Nancy P. in forum Applications and Operating Systems
    Last Post: October 12th, 2004, 11:46 AM
