help, been hit by a nasty virus
Currently Active Users: 1649
Discussions: 200,924, Posts: 2,379,112, Members: 246,290
Old July 4th, 2002, 04:27 PM   Digg it!   #1 (permalink)
jak
jak's Avatar
Send a message via AIM to jak
my dads laptop got a nasty virus from a work partner, the virus will kill norton antivirus if you try running it, its on a laptop running windows xp, for some reason i cant scan his laptop from my computer on teh network, it wont let me see him, any suggestions on how to get rid of this sucker, its a tough one and as you all know reloading operating systems on laptops can be a b****, would a rescue disk for dos run on a laptop with xp, seeing as how xp doesnt have dos. or am i dead wrong?
jak
btw he said it left a error message that read: brnd.log when he first got it, i can seem to find the .log file on the hdd. any help would be very very very appreciated
jak is offline   Reply With Quote
Old July 4th, 2002, 05:00 PM     #2 (permalink)
iNsAn3 mEMBER
Daft_Ghosty's Avatar
Send a message via ICQ to Daft_Ghosty Send a message via AIM to Daft_Ghosty Send a message via MSN to Daft_Ghosty Send a message via Yahoo to Daft_Ghosty
well if it is XP can he not revert back to the last backup of xp.. and get rip of the virus that way?
u might also try www.sarc.com its a online detecter.. it may find it.. and then it can tell u how to clean the system.. even as small programs ment to cleanr certian viruses
In life one must Chill
Daft_Ghosty is offline   Reply With Quote
Old July 4th, 2002, 05:51 PM     #3 (permalink)
Get norton antivirus and have your laptop boot from cd-rom(norton antivirus cd is bootable) by going into the bios and changing the boot order. It has everything there needed to save your computer : )
Mithin is offline   Reply With Quote
Old July 4th, 2002, 07:18 PM     #4 (permalink)
jak
jak's Avatar
you know i never thought of those, the heat is killer on teh brain today thanks much ill go give it a try
http://gorillasmashserver.com {Gorilla:Smash:Server}
Share your scripts, ideas, talents, questions, and concerns!
Old July 4th, 2002, 07:21 PM     #5 (permalink)
eweruk's Avatar
Send a message via ICQ to eweruk Send a message via AIM to eweruk
The CD will not have the virus pattern or scan engine to clean it. This sounds like the Kleaz virus, go to Trend and download the fix tool and follow directions. Once the virus is killed, reinstall Norton and update scan engine and virus pattern. Scan and repair damage.
eweruk is offline   Reply With Quote
Old July 4th, 2002, 08:15 PM     #6 (permalink)
jak
jak's Avatar
imdoing the klez removal right now, yea the cd boot deal didnt work, uhh this is taken a darn long time, its been scanning for almost a half hour now in command line, well ill get back to ya with an update, lets hope your right about it being klez
thanks much
Old July 5th, 2002, 01:02 AM     #7 (permalink)
jak
jak's Avatar
i think that did the trick, i installed norton, finish up scanning in the morning, thanks much to all, really appreciated
jak
Old July 5th, 2002, 01:22 AM     #8 (permalink)
eweruk's Avatar
Great, glad I could help!
Old July 5th, 2002, 01:46 AM     #9 (permalink)
Cody's Avatar
Oh Super!
- Cody
The Thing™
Cody is offline   Reply With Quote
Old July 5th, 2002, 03:12 AM     #10 (permalink)
fyxxer32's Avatar
Ive been following you guys on this and youre very sharp on it. No wonder I hang out here !
fyxxer32 is offline   Reply With Quote
Is It Just Me? (2859)
Obama the Muslim (14)
Optical Audio A-B Switch (0)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
