Results 1 to 4 of 4
Thread: HDMI Problem
    Mar 2004
    72
    HDMI Problem
    I am having a problem, with my HDMI Cable. Here is the problem. I have an HDTV, I have my HDTV connected to my cablebox, using and HDMI cable. I am using an HDMI cable that I bought from Monoprice, it is a standard cable, at least that is what I am lead to believe, from the different articles that I've read on the Internet. My problem is sometimes when I am changing channels on my cable system sometimes the sound goes out, and for some reason, there is always one channel that I can go to, that will bring the sound back. My question is, if I buy a "High Speed HDMI Cable," would that solve my problem? I have checked with my cable company about the problem. They gave me a new cable, but that did not solve the problem, and I don't think that they gave me a High Speed Cable.
    Thanks In Advance for any help given.
    Feb 2007
    Springfield
    13,484
    5
    I've never known an "high speed" HDMI cable to change anything, other then the price tag to be honest. If you needed something like 20'-30', then ya I might spring for something of better quality. But if it's a shorter cable, there is no need for it. Honestly, it sounds like either you cable box is being screwy, or possibly your TV. Have you checked with another device/port on the TV to see if it happens on everything you attach?
    FAQ's ~ Team Stats
    My PC
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    This cable company, will, send you a free HDMI cable to disprove the myth, on HDMI cable pricing.
    They clam their free cable is as good as any cable in existence
    Kogan offers free HDMI cables to end cable con | Expert Reviews
    Seems to me, I saw a German company, offering the same thing, a while back
    Hard Sayin Not Knowin
    ΜΟΛΩΝ ΛΑΒΕ no1_vern's Avatar
    Apr 2002
    Albany, Ga.
    18,486
    That sounds like a configuration issue, not a cable issue. IF you were able to jiggle the cable, and the sound came back, then I would agree it might be the cable.
    Have your cable company come out and check your receiver, and the signal-its usually free. I strongly suspect the box to be the culprit. I had to replace my receiver last year because even though I had a good signal, the sound to my TV kept cutting out.
    dulce bellum inexpertis
  1. dynex hdmi problem
    By oscar20 in forum Technical Support
    Last Post: March 3rd, 2010, 09:10 AM
  2. PC: DVI to HDMI Sound Problem!
    By Cappy445 in forum Multimedia and Audio
    Last Post: October 10th, 2009, 01:36 AM
  3. Gateway HDMI connection problem
    By djupdown in forum Technical Support
    Last Post: June 5th, 2009, 01:52 PM
  4. Nvidia 9600 GS HDMI Out problem
    By skill52 in forum Graphics Cards and Displays
    Last Post: October 31st, 2008, 08:59 AM
