Thread: HP Pavillion bradcasting...
May 5th, 2012, 06:32 PM #1Member
- Apr 2004
- 476
A friend purchased an HP midtower CoreI3 With Win 7. They do not have, or plan to have a home network. Is there a way to tell if it is broadcasting a signal, allowing other computers to access it via wireless ? if so how to disable this ?
May 5th, 2012, 06:53 PM #2
Install this to a laptop. Downloads | NetStumbler
May 6th, 2012, 06:46 PM #3Member
- Apr 2004
- 476
Hmmm ok.. Is that the the only way to determine if their computer is broad casting a wireless signal ? Can broadcasting be manually disabled ?
May 6th, 2012, 06:53 PM #4
Uhh why not just check the specs and if it even has a wireless card just disable it in the device manager? Then if you still suspect something use NetStumbler, Wiki will tell you what it does BTW NetStumbler - Wikipedia, the free encyclopedia
May 6th, 2012, 06:59 PM #5Member
- Apr 2004
- 476
Thanks Rich, you just answered my question
And yes, it does have a wireless card installed.
May 6th, 2012, 07:04 PM #6
In general you don't just gain access to a random computer just because it has a wifi card. I mean not many hackers are wardriving houses looking for a possible connection like that. But if its a real concern they should also be able to remove the card itself.
May 7th, 2012, 10:30 AM #7
I would remove the card. But disabling it in the device manager is a solid second choice, if no other operating system will be used.
They are using a wired link to their internet router/modem, I take it?
hp pavillion battery
By babst in forum Technical SupportReplies: 1Last Post: August 24th, 2008, 06:57 AM -
Pavillion Recovery CD
By frustrated6636 in forum Technical SupportReplies: 6Last Post: March 24th, 2004, 09:16 PM -
HP Pavillion 7840
By DoctorReno in forum MotherboardsReplies: 2Last Post: August 9th, 2003, 09:46 PM
IRS scandal a reminder of how I learned about the Chicago Way - chicagotribune.com I think Obama is going to understand America is bigger than Chicago real soon, too.
John Kass: IRS Scandal a Reminder...
