June 15th, 2012, 04:41 PM #1Junior Member
- Jun 2012
- 3
Everything is shadowing from and Xbox 360 to a 1920x1080 monitor.
I just received an Xbox to VGA cable for my computer monitor. When I plug the VGA into the monitor, it picks it up but it shadows EVERYTHING. It's quite annoying when trying to play a game. I have shared a link at the bottom so you can see for yourself what is happening.
If you have any idea why this is happening, could you please tell me what is wrong and if you know how to fix it, that would be awesome as well.
If you need more information that I haven't given you, please ask!
Here is the video to the example.
Monitor shadowing issue - YouTube
June 19th, 2012, 04:49 PM #2Junior Member
- Jun 2012
- 3
bump?
June 19th, 2012, 05:23 PM #3
Since you just received the item, I would assume it is damaged. Send it back for a replacement.
I'm guessing the monitor doesn't have HDMI? Or is it an older X-box that lacks this? I think the best solution would be HDMI out from the Xbox to HDMI in on the monitor. Since you are downscaling a digital signal (guessing) to the analog VGA there is always the possibility of ghosting. VGA just can't handle the high-res signals that well.Good job, friend-of-friends!
June 19th, 2012, 05:44 PM #4
As Tony advised, it is more than likely ghosting from the switch. On that note, I've had nothing but trouble with converters as well, so ideally if there is an hdmi available use that (though I would think you would have gone that route initially if available)
XBOX 360 to HD monitor
By rebe72 in forum Technical SupportReplies: 13Last Post: October 30th, 2011, 05:37 AM -
Xbox 360 on an LCD Monitor using the 360 VGA HD AV Cables?
By pepsiclock in forum General Tech DiscussionReplies: 6Last Post: December 24th, 2009, 09:37 AM -
Xbox 360 on a monitor
By qrs321 in forum Graphics Cards and DisplaysReplies: 11Last Post: February 24th, 2009, 11:04 PM -
16:9 monitor for XBOX 360
By mehedi447 in forum Graphics Cards and DisplaysReplies: 0Last Post: February 5th, 2009, 01:23 PM
that was easy, if only deleting the partition was that simple.
