Thread: Can I change the Power Supply?
June 20th, 2012, 02:12 PM #1Junior Member
- Jun 2012
- 2
Hi! I need your guys help... So first I have a 250 watts power supply and I want to change the power supply to I don't know something like 300 or 400 watts depends on my budget. The problem is that I don't know if the 300 or 400 watts power supply would fit in my system unit cause normally, 300 or 400 watts usually have bigger system unit and I don't know if it will fit...
Here's the link to what my system unit looks like:
Google Image Result for http://www.abcua.com/images/goods/5470/12178_b.jpg
June 20th, 2012, 02:17 PM #2Junior Member
- Jun 2012
- 2
oh yeah I forgot, what would be the problems if I change the power supply
June 20th, 2012, 03:16 PM #3
The internet seems replete with a lack of information regarding this unit's power supply. It's hard to say. If it's a standard PSU, then it should be easily replaceable, however a lot of those types of units have specially sized units to make them fit.
June 20th, 2012, 09:55 PM #4Member
- Dec 2011
- Location
- NJ
- 73
I'd be careful when it comes to power supplies. A lot of the other components can be changed without too much trouble, but the power supply can be dangerous. Is your power supply not supplying enough power to the components in your computer? (I can only imagine this would be a problem if your computer is custom built or if you have switched out some of the components that came with the computer when you bought it.)
Remember, if you get this wrong you run the risk of frying your computer or worse, being seriously hurt. With just about any other part I'd say do it yourself, but if it were me dealing with a power supply, I'd take it to a professional or see if the vendor provides some sort of service to do this.
Cooler Master Real Power Pro 1250w Power Supply Review
By RobRich in forum Tech News DiscussionReplies: 0Last Post: August 11th, 2008, 12:53 PM -
PC Power & Cooling Silencer 750 Quad Power Supply Review
By RobRich in forum Tech News DiscussionReplies: 0Last Post: May 15th, 2008, 06:32 PM -
How to Change or Find 610 Gateway Power Supply
By onder in forum Technical SupportReplies: 0Last Post: January 10th, 2006, 11:12 AM -
Power Supply change - how hard?
By bob733 in forum PC ModificationReplies: 8Last Post: February 26th, 2003, 10:29 PM
Honestly if it were me, I'd go with a single newer better card, one with 2GB Memory on it. The 6850's in Crossfire, can equal a single Radeon HD 7950, in some games, and some resolution settings,...
Graphics Card recomendations wanted
