Thread: I need suggestions please...
July 10th, 2012, 12:52 PM #1Junior Member
- Jul 2012
- 6
Hi. I'm buying a new gaming computer and I want you guys to suggest me if its ok to max out all bad-ass games.
Spec.
INTEL CORE i3 2120 3.30Ghz (3MB CACHE)
KINGSTON DDR3 8GB-1333
COOLER MASTER CHASSIS CM ELITE 333 WITH 600W POWER SUPPLY
HD 6850 256 Bits 1024MB DDR5 775MHZ SAPPHIRE.
July 10th, 2012, 01:04 PM #2
Thread moved to the right area
July 10th, 2012, 01:10 PM #3Junior Member
- Jul 2012
- 6
Where's the right Area?
July 10th, 2012, 01:12 PM #4Junior Member
- Jul 2012
- 6
Here it is.. Okay well?
July 10th, 2012, 01:15 PM #5
I moved it for you already.
What games are you wanting to play? How much do you have to spend? Where do you live? Are you building this yourself or is it a prebuilt machine?
July 10th, 2012, 01:24 PM #6Junior Member
- Jul 2012
- 6
I'm building this myself and I want to play BF 3, Crysis 2 and skyrim. Can I max out all these games with this spec? Please answer..
July 10th, 2012, 01:31 PM #7
no, not even close.
what you have selected is a budget to lower mid range specs list.
if you want to max out or as close as possible, your going to need a card twice as powerful at least (250-300+ bucks), and a Quad core.
or even Dual Video cards.
oddly 8GB is actually more than you'll need in RAM, 4GB is plenty.
you'll also be needing to run 64-bit version of Windows to use all that Memory plus the video card Memory.
The only one of the 3 games you list that might be able to run pretty well on high settings is Skyrim, since its much more adaptable to the hardware on systems, the other two games you'll be lucky if it runs at decent frame rates on moderate settings.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
July 10th, 2012, 01:52 PM #8Junior Member
- Jul 2012
- 6
Dual video cards? Lol okay thanks for your answer.
July 10th, 2012, 01:58 PM #9
Shyguy hit the nail on the head, that system isn't coming close to maxing out those games.
This said, are you building it yourself, or buying one pre made?
Either way, what is your budget and when do you plan to buy?
Also by dual videocards he means SLI (Nvidia) or Crossfire (AMD)Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
July 10th, 2012, 02:01 PM #10Junior Member
- Jul 2012
- 6
Wait! Dual video cards? BAHAHAHHAHAHAAAAAAAAAAA MAN... You're hilarious!
July 10th, 2012, 02:04 PM #11Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
July 10th, 2012, 02:23 PM #12
Shy and Solo have answered your question.
What is your build budget, and what country are you located in so we can suggest the best parts for your budget.The timing of death, like the ending of a story, gives a changed meaning to what preceded it. -Mary Catherine Bateson-
July 10th, 2012, 02:28 PM #13
How about 3 or 4 cards then?
Capable or running 3 or 4 cards if necessary.
only have the one card in right now, but its capable or running 2 or more easily.
Solo has the same PSU, and slightly faster card, and can actually run 3 of them (GTX 480 is capable of 3 Way SLI, GTX 560 Ti I have is only Dual capable, but my GTX 470 is 3 Way capable)i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
July 10th, 2012, 02:31 PM #14
just a side note, the System I have runs Skyrim on maxed out settings with 1080p res and I can get at least 60fps or more.
I don't have Crysis 2 or BF3 yet, waiting to get those at bargain bin prices so no idea how they'll run, but from what I have read, they should run on moderate settings at decent enough frame rates.
Even my "older" system with a Core i7 920 Quad core instead of the 940 I have now, and my GTX 470 was able to run Skyrim nearly maxed out.
http://i10.photobucket.com/albums/a1...g/PICT0123.jpg
I have a GTX 285 parked along side it for PhysX and to be used for some GPU Processing software like Folding@Home, and Badaboom 2.0.
Its not an SLI setup, but thats what a dual card setup would look like, minus the SLI bridge adapter connecting the 2 cards.Last edited by ShyguyXPC; July 10th, 2012 at 02:34 PM.
July 11th, 2012, 12:13 AM #15Junior Member
- Jul 2012
- 2
Custom PC
Hey,
Whats your budget look like? I have a custom pc that I am selling off. It will play anything you throw at it. I would be looking for around $950, but throw me an offer if interested.
23 inch Acer HD LED Monitor
Windows 7 Home Premium 64 bit x64
Intel i5 2500K Sandy Bridge 3.3GHz
8 GB DDR3 Performance Ram
NVIDIA GeForce GTX 570 Video Card
ASUS P8P67 PRO LGA
WDC 1TB Hard Drive HD
2 MultiLayer CD/DVD Player Burners
950 W Corsair Power Supply
Corsair Hydro Series CPU Cooler
Cooler Master HAF Series Case
July 11th, 2012, 12:41 AM #16
this should really be posted in the area set aside for buying/selling/trade.
New member with no prior posts, or rep, or even sales, posting in a thread like this, is a bit suspicious as well.
Traders Forum: Buy, Sell, Trade Stuff - ResellerRatings Store Ratings
Should really be posted there, but can post a link to it in this thread so they no where to go to look. (as there are some rules for selling on here)
Traders' Rules, Tips, & Tools - ResellerRatings Store Ratings
Should also specify the Brand/Series/Model of the RAM you have, as well as the Brand and if possible model/part number of the Video card (as most brands make more than one variation with cooler designs and clock speeds), also Which Corsair Hydro Series Cooler, as there is the H40, H50, H60, H70, H80, and H100 models. Which CM HAF Case, there is more than one.
Which Acer LCD, again, generalized info, Which model, so they can look up specs on it.
Has the CPU been Overclocked, if so, how high, and what was its operating temps, and Voltages, also if RAM has been OC'd add that info as well.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
July 11th, 2012, 02:38 AM #17
Its fine for what it is, listed, and able to play games, but not for what they're asking about.
and a 1GB Nvidia card... ok, well if you know what your talking about, which one?
1GB Low end GT 430? 1GB GTX 550 Ti, 1GB GTX 560 or 560 Ti, 1280MB GTX 570, 580, GTX 670, 680? what?
Oh, and the little fact that they already have a Video card listed, 1GB Radeon 6850.
which would near the same range as a GTX 550 Ti to a GTX 560.Last edited by ShyguyXPC; July 11th, 2012 at 02:43 AM.
July 11th, 2012, 11:35 AM #18Junior Member
- Jul 2012
- 2
My apologies, I do not mean to break any forum rules. I will use the Buy, Sell, Trade Forum. Just to quickly answer your questions. It is a Hydro H60. While the ASUS motherboard has built in overclocking capabilities, I have never overclocked any of its components. The case is HAF 932 Avanced RC-932-KKN5-GP Black Steel ATX Full Tower. Here are the details. Newegg.com - COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan
The Memory - Patriot Division 2 Viper Extreme PC3 12800
Newegg.com - Patriot Viper Xtreme Series, Division 2 Edition 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PXD38G1600LLK
The monitor is an Acer S231HL
Newegg.com - Acer S231HLbid Black 23" 5ms HDMI LED-Backlight LCD monitor Slim Design 250 cd/m2 ACM 12,000,000:1 (1000:1)
Graphics EVGA GTX 570
Newegg.com - EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
July 24th, 2012, 03:43 AM #19
is what possible to run Dual cards?
Two Suggestions...
By The Real Bingo in forum Suggestion BoxReplies: 10Last Post: June 22nd, 2007, 02:21 PM -
Sound card suggestions/problem/speaker suggestions
By andlamv in forum Graphics Cards and DisplaysReplies: 11Last Post: August 11th, 2004, 02:46 AM -
Need Suggestions
By photos911 in forum Webmastering and ProgrammingReplies: 33Last Post: June 11th, 2002, 11:11 PM -
Any suggestions?
By e980238 in forum Webmastering and ProgrammingReplies: 1Last Post: April 2nd, 2002, 02:04 PM
Star Trek Into Darkness Download What I loved concerning William Shatner’s execution as Leader church building was gratify aforesaid Pine. “It’s reflected during this pic and it’s what J.J....
Star Trek Into Darkness Download...
