Results 1 to 3 of 3
    Mar 2004
    72
    Home Stereo Problem
    I am having a problem, with a Home Stereo. It is a "GPX HM2855," the problem I am having is, The stereo will turn itself on and off, by itself. I have done everything that I can think of. I have read that some GPX Models have a reset button, but wouldn't you know that this model does not. I have tried unpluging it, but that doesn't seem to help either. Thanks in advance for any help.
    Dec 2008
    East Chamunga
    2,362
    Could be a dirty or malfunctioning On/Off switch... get some electronics cleaner spray from yer local auto parts store and give it a shot...
    ◄ it is what it is ►
    Dec 2010
    Lebanon
    310
    If cleaning the on/off switch fail , then you should consider opening the stereo and look for an overheating component ; In your case , it could be the main Audio chipset failing randomly, or the cooling lubricant between the chipset and its heat sink had dried ..
  1. Using PC Speakers as home stereo?
    By agathodaimon in forum Multimedia and Audio
    Last Post: May 17th, 2009, 11:39 AM
  2. home stereo amps
    By sr71000 in forum Multimedia and Audio
    Last Post: June 13th, 2005, 06:59 PM
  3. Help w/ choosing car stereo parts for home stereo
    By ArcticFox in forum IMO Community
    Last Post: July 23rd, 2004, 02:54 PM
  4. Home stereo thru PC...what's the best way?
    By Not 2 Techie in forum Multimedia and Audio
    Last Post: August 11th, 2003, 09:20 AM
