Results 1 to 8 of 8
    Feb 2011
    61
    Question Use of VGA cables
    I have an Acer Aspire 5517 laptop which I connect to a 23 inch Polaroid TV with a Belkin VGA cable. The problem is that using the cable invariably scrambles my screen icons. I have to manually restore them to their original positions. It's a real pain. I've tried several downloads that claim to hold icons where they belong with only partial success. My question is this: Is there a way to avoid this from happening when I use my VGA cable? It must change the resolution but I don't know why or how to avoid it. Your assistance will be greatly appreciated.
    West Haven, Utah
    32,659
    Look at the screen resolution while it's connected to the TV, then make sure that it's set to that same resolution when it's not connected to the TV. Hopefully that would do it.
    Feb 2011
    61
    Ok. One last thing. How do I check the resolution?
    Aug 2003
    Gateshead U.K.
    11,312
    Depends on the operating system you are using. The T.V. will usually flash a display info box with the resolution in use, as it finds the signal from the laptop, though. Probably 1360 x 768 or 1366 x 768 for a widescreen LCD T.V.
    Feb 2011
    61
    Ok. Thanks.
    West Haven, Utah
    32,659
    In Windows 7, right-click on the desktop and select screen resolution. For other earlier operating systems, also right-click, but I don't remember off the top of my head which option to click. Maybe display settings?
    Frick tony_j15's Avatar
    Mar 2003
    Joplin, MO
    14,127
    If it's an installed option. Otherwise right click > properties > display tab.
    Good job, friend-of-friends!
    Feb 2011
    61
    Thanks guys. Not on that laptop at the moment but I'll get it done when I get back to it. I've got Windows 7. I should have mentioned that. Thanks again.
  1. Splitting VGA into VGA + Component cable?
    By GypsyMods in forum Multimedia and Audio
    Last Post: August 15th, 2011, 01:07 PM
  2. Xbox 360 on an LCD Monitor using the 360 VGA HD AV Cables?
    By pepsiclock in forum General Tech Discussion
    Last Post: December 24th, 2009, 09:37 AM
  3. Cables... Cables... Do I Need to Buy Them?
    By v0lume4 in forum General Tech Discussion
    Last Post: April 9th, 2009, 12:41 AM
  4. Replies: 2
    Last Post: October 19th, 2008, 06:06 PM
