My TV-Out won't work... Help!
Currently Active Users: 1169
Discussions: 200,929, Posts: 2,379,147, Members: 246,296
Old August 2nd, 2002, 03:58 PM   Digg it!   #1 (permalink)
Ryder Zery's Avatar
Send a message via AIM to Ryder Zery
Unhappy
I bought a video cable from Radio Shack today and got it all hooked up to my computer and TV. Now I go under Control Panel, Display, Settings, then click on the nVeiw tab. Where I'm supposed to choose analog display, digital display, or TV, the TV option (and digital display) is greyed out, like it isn't detecting the TV.
Any help? I have a Gateway Performance 1400, PNY Verto GF4 Ti 4200, and Win XP. I called both Gateway and PNY and they couldn't help me. I have all the latest drivers for everything too.
Ryder Zery is offline   Reply With Quote
Old August 2nd, 2002, 04:05 PM     #2 (permalink)
Did you try changing the cable??
It may be defective.
sMoKiE is offline   Reply With Quote
Old August 2nd, 2002, 04:39 PM     #3 (permalink)
Ryder Zery's Avatar
Possibly... the cable was opened (previously returned) so it is a possibility. But when I turn on the computer, my TV screen flickers and shakes some, so it's apparently detecting something.
Old August 2nd, 2002, 04:41 PM     #4 (permalink)
A hero in training
GroundZero3's Avatar
at the area you choose tv or analog there should be a button at the bottom detect displays. have you tried that?
i see the option on my laptop. just a suggestion
GroundZero3 is offline   Reply With Quote
Old August 2nd, 2002, 04:42 PM     #5 (permalink)
bigblue77's Avatar
Send a message via ICQ to bigblue77 Send a message via AIM to bigblue77 Send a message via Yahoo to bigblue77
I had to check the "force detection" or something like that to get mine working. It would not see my TV automatically. The problem went away after I forced the detection.
Jer
Thread Killer
bigblue77 is offline   Reply With Quote
Old August 2nd, 2002, 04:45 PM     #6 (permalink)
Ryder Zery's Avatar
I tried the "detect displays" button and it still won't detect it.
And where is the "force detection" feature?
Old August 2nd, 2002, 05:15 PM     #7 (permalink)
bigblue77's Avatar
Right click on desktop > properties > settings > advanced > nView > it should be a check box near the bottom of the page.
Jer
Old August 2nd, 2002, 05:43 PM     #8 (permalink)
thekemp's Avatar
have you tried it with composite, how hold is your tv?
i bought brand new though cheap set and it wouldnt work with s-vid
thekemp is offline   Reply With Quote
Old August 2nd, 2002, 06:00 PM     #9 (permalink)
Ryder Zery's Avatar
I couldn't find any "force detection" check-box bigblue, you must have a different version of nVeiw or something?
And I'm not using S-Video, I'm using AV I think (red, yellow, and white)?
Old August 2nd, 2002, 06:12 PM     #10 (permalink)
bigblue77's Avatar
Hmm, I am using the newest drivers(I think). Oh Well. Maybe somebody else has more info for you.
Jer
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
