Results 1 to 5 of 5
    Member Top Gun's Avatar
    Jan 2002
    From the skies above
    405
    How to disable bluetooth scanning in Android 5.0?
    How do I disable bluetooth scanning in Android 5.0?
    Never interrupt your enemy when he is making a mistake.
    Dallas, TX
    12,971
    The "Notification Panel" that you slide down from the main screen.
    "Common Sense is a flower that doesn't grow in everyone's garden."
    Smile. It's easy. :) paul9's Avatar
    Aug 2003
    Gateshead U.K.
    14,175
    I think he wants to disable the device scanning whilst leaving Bluetooth itself enabled, Steve.
    I wasn't really aware that scans were performed outside of when you requested them, and maybe when Bluetooth was initially turned on. Just been looking on a 6 series device and can't even see how to turn off visibility anymore. That and a 5 series didn't see each other until I told them to scan, though.
    Dallas, TX
    12,971
    Paul - you're probably right... My Android 5 gives me the impression it scans on demand... It's lists my car and two unknown devices AND a scan option.
    Jan 2002
    405
    Yup that's right...In Marshmallow there's an option to disable both wifi and bluetooth scanning but in Lollipop, I can't seem to find the option to turn off bluetooth scanning.
  1. Scanning problem
    By Theophylact in forum Technical Support
    Last Post: December 2nd, 2008, 12:36 PM
  2. disable hibernation... and i mean really disable it!
    By zskillz in forum Technical Support
    Last Post: June 13th, 2008, 03:01 AM
  3. Scanning Docs
    By Mombo323 in forum Applications and Operating Systems
    Last Post: March 30th, 2006, 11:58 PM
  4. Somebody is scanning your computer
    By woodbutcher in forum Security and Privacy Issues
    Last Post: July 21st, 2004, 01:08 PM
