Results 1 to 3 of 3
    Steeler Fan jman01pa's Avatar
    Louisville KY
    3,251
    Help with adding memory to a Toshiba Satellite Laptop
    I get to help someone add memory to a Toshiba laptop model 225CDS over the phone. I think the memory slot is under the keyboard but I am not sure enough to have them start removing things without knowing. If someone can verify this or tell me where it is if I am incorrect, it would help me a lot.
    Thanks in advance
    J
    Ultimate Member PoonDoggy's Avatar
    San Antonio, Texas,
    2,045
    It is either under the keyboard or underneath the laptop. I am searching Toshiba's site for spec's, but so far, no good.
    The Beatings Will Stop When Morale Improves
    addicted DVNT1's Avatar
    Ohio
    6,103
    All Toshiba Satellite's I have added memory to are directly under the keyboard.
