weird win2000 problem with shortcut keys
Currently Active Users: 2367
Discussions: 200,941, Posts: 2,379,265, Members: 246,304
Old October 6th, 2002, 12:15 PM   Digg it!   #1 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
ok, i have a weird problem going on with a win2000 machine pertaining to shortcut keys bound to my desktop icons.
i've recently just built a w2k replacement box for my aging NT internet machine and now my shortcut keys don't work anymore.
for example: i've bound ctrl-alt-o to launch outlook express. but even though the shortcut shows up under Properties, when i press those keys, it refuses to launch. if i delete the shortcut key and recreate it again, it will only work during the current boot session. the next time i reboot the machine, i lose it again.
has anyone ever seen this or knows what the problem could be?
ps. i'm not complete sure when this stopped working because i've only used the machine for 3-4 days. i had installed sp3 (with the backup option) recently but i deleted the uninstall folder 24hrs later afterwards, so now i can't roll it back. grrrr!
Old October 6th, 2002, 06:48 PM     #2 (permalink)
^bump^
anybody ?
Old October 8th, 2002, 09:16 AM     #3 (permalink)
The Nebish Jurist
Brangwen's Avatar
PresterJohn:
I'm a relative newbiew to Win2KPro ... I wasn't even aware of shortcut keys! I suspect you've surmised the shortcut you create each session simply is not being "saved." Like something being set up in RAM. Either that or the shortcut compiler or whatever creates and/or controls that code is resetting to default when you end your session.
In short, I've no specific fix to your problem, nor have I experienced it (see above). Just a few "how come?" ideas.
Good luck. I'll look in my manual and check out "saving" shortcut keys once configured.
Brangwen
ASUS A7N8X-E Deluxe, Athlon XP 3200+, 1.5 GB Samsung [400 MHz] DDR, Matrox Parhelia 128 Graphics, Dual LG FLATRON Displays, WinXP Pro SP3
Brangwen is offline   Reply With Quote
Is It Just Me? (2911)
Wireless Televisions. (8)
Regular Build (6)
Obama the Muslim (14)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
screen resolution vs monitor size (0)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
