I got a CoolerMaster ATC-201 Case and tried 2 different motherboards and the LED lights for HDD Led and Power LED wont turn on. I tried every way the connectors could connect to no avail. Is there something I could buy to test it? Could it be the lights or the wires? How does one go about fixing this?
Thanks =)
It's all fun an games till little Billy get his Cornea scratched.
You could test the LED's with the same multimeter. Set it to ohms scale and hook it to your LED to be tested. It should read continuty one way and an open circuit when the lead polarity is reversed. It seems unlikely that you would end up with 2 bad LED's on the same case. . . . . stranger things have happened, though.
