Join TechIMO for Free!
Thread Tools
Currently Active Users: 3010
Discussions: 186,621, Posts: 2,227,172, Members: 230,251
Old October 29th, 2002, 07:25 PM   Digg it!   #1 (permalink)
Hard Drive Not Detected
Have Pent III 500 mhz. 2 hard IMB hardrives. Has been working well but wanted to increase RAM from 512 to 1025mb. Installed 2 more 256mb rams but system only shows 128 mb each. ASUS P2B-F m/bo. Asus says I needed 256 double-sided. Returned my rams for 256 d/s ram. System keeps hanging up so I returned and resinstalled 1-256 and 3 128's for 655mb total. Now I can't boot up up windows.
BIOS doesn't see to recognize my two hard drives, but does recognize my two cdroms. I go into BIOS setup main memu. Primary Master and Slave show (auto). I hit enter on AUTO Primary and my disc shows IMB etc and all sector info. I save and exit and reboot. BIOS msgs shows detecting Primary hardrive and then displays (NONE), same for Secondary which displays (NONE).
I have tried booting up from startup disks but since my hard drive is not being recognized, that isn't working. I'm ready to FDISK and reinstall everything but can't get past IDE hard drive detection failure.
Should I try another harddrive. Should I manually enter the settings for the harddrive.
Help, i'm getting frustrated.
WilliamRyan is offline   Reply With Quote
FREE instant scan
Old October 29th, 2002, 07:45 PM     #2 (permalink)
OH NO!
Brainchild's Avatar
Send a message via Yahoo to Brainchild
welcome to TechIMO
I would try clearing the CMOS, see if that helps.
Brainchild is offline   Reply With Quote
Old October 29th, 2002, 08:01 PM     #3 (permalink)
woodbutcher's Avatar
Have you tried going back to your original mem cofiguration.
woodbutcher is offline   Reply With Quote
Old October 29th, 2002, 08:04 PM     #4 (permalink)
I know when I have replaced memory befor I pulled my HD IDE cables out just enough to cause problems. Try reseating them on both the mobo and at the drives. Also try booting up with just 1 stick of memory installed.
Good luck,
cstierhoff
Out Playing in Traffic
cstierhoff is offline   Reply With Quote
Old October 29th, 2002, 08:09 PM     #5 (permalink)
Thanks for the response. I'm checking the P3B-F manual. Please explain 'clearing the CMOS'. If I undersand, I need to reboot from the original or updated mobo BIOS that I should have created as a bootable floppy disk. If I can't find it, try finding the source somewhere and use that to boot from. This process uses the Flash Memory Utility Writer (AFLASH.EXE).
Old October 29th, 2002, 08:22 PM     #6 (permalink)
Sounds there as your reading the bad flashing of bios section.
Your board may not have a Clear CMOS option. Look in the manual and see if you can find a "JP" for clearing the CMOS.
WB
Old October 29th, 2002, 08:28 PM     #7 (permalink)
uethello's Avatar
I'd take it down to the minimum with the RAM, first thing, take everything but one stick (a known good stick, if possible) of RAM and then try hunting the problem. If you boot, etc with no problem, it's memory related.
uethello is offline   Reply With Quote
Old October 30th, 2002, 06:20 PM     #8 (permalink)
Thanks for the advice. I replaced the 256mb ram that was showing only 128 mb with a 128mb ram. Then pulled drive cable and reseated the connection. Disconnected my Prim Slav and rebooted. My BIOS setup showed the Prim Mast drive and windows installed fine.
Old May 15th, 2008, 12:25 PM     #9 (permalink)
Send a message via MSN to Patricia_paragon
Unhappy
I NEED HELP!!!!!
My brand new Dell inspiron 1525 isnt reading the HD and i cant figure out why .. I't new like i said .. i havent even made the first payment on it and it just stopped working!
can anyone help me figure out why this isnt working or reading the HD anymore... I don't want to lose everything on there.
I havent had time to backup anything due to it being so new.
I'm being sent a new HD but thats not the point... I'm also wondering how long this new one will last.
I'd hate to return the whole computer.
HELP!!!
Patricia_paragon is offline   Reply With Quote
Old May 15th, 2008, 12:28 PM     #10 (permalink)
Unhappy
I NEED HELP!!!!!
HELP!!!
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (557)
Transfering balances from one credi.. (6)
Misery Loves Company... (1854)
Linksys WRT54G (5)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (15)
1 internet. 1 house. 3 computer. ho.. (14)
is there a way to Grep for a sp.. (0)
Painfully Slow eSata External 1.. (0)
Help with broken bracket from A.. (3)
RAID 0 External Drive Slow/Fail.. (2)
Switching HDDs (1)
new kid (0)
Benefits of having two separate.. (1)
Laptop doesn't stay connected t.. (10)
Hard Core Overclock (14)
