Results 1 to 4 of 4
    May 2002
    Merseyside UK
    114
    swaping variable a for b and vice versa in VB
    is there a 'swap' command in VB or somethng simialr to do what i want to in the subject ?
    P.S its VB 5 i'm using i have access to VB 6 though
    West Haven, Utah
    32,753
    Maybe this is too simplistic, but
    set var c = a
    set var a = b
    set var b = c
    or something like that should work if I understand what you want to do.
    Not Really a Member
    27,879
    umm don't know of a swap function but if you convert howste's code to vb you should be ok
    Dim a
    Dim b
    Dim c
    c=a
    a=b
    b=c
    West Haven, Utah
    32,753
    Obviously I've forgotten some pretty basic VB code stuff. Do what Vass said.
