dual booting
Currently Active Users: 2051
Discussions: 204,295, Posts: 2,417,061, Members: 249,714
Old November 7th, 2002, 07:09 PM   Digg it!   #1 (permalink)
Question
dual booting
how do i dual boot on the same hard drive i have 4 hdds on my comp but i want to try it on the same hdd one other thing i erased my partion and formated my hdd and now it wont let me do anything in DOS not even bring up help or fdisk or scandisk am i in deep &%$$ i dont have a boot disk
Zidane is offline   Reply With Quote
Old November 7th, 2002, 07:23 PM     #2 (permalink)
Love2Learn's Avatar
Send a message via ICQ to Love2Learn
what opperating systems do you want to use? what is your computer? do you have the operating systems disk(s)? im no expert but i might be able to help you
-L2L
ASUS 7900GT 256MB
Hauppauge pvr 150 MCE
Pentium D 930
ASUS P5WD2 P
4gb CORSAIR DDR2
2 WD Raptors 74GB (RAID 0)
Antec Lanboy case
Windows XP MCE
Love2Learn is offline   Reply With Quote
Old November 7th, 2002, 07:50 PM     #3 (permalink)
JacobM5727's Avatar
Send a message via ICQ to JacobM5727 Send a message via AIM to JacobM5727 Send a message via Yahoo to JacobM5727
so you have four blank drives?
make a bootdisk on the comp your on, if you dont have windows 98, you can get one from http://www.bootdisk.com
first you should put two partions on your os drive, and install each os to a diff one.. or if not you may have issues
if you want to duel boot with 98/2k
install 98 first, 2k will detect it
do not use ntfs if you want to be able to use that drive with windows 98
2k and xp
install either first
98 and xp
not to be installed on the same partition as they both use the windows folder - install 98 first
98 and linux, 98 first
linux and 2k/xp, you may not be able to use ntfs
install the windows first.
example:
drive #
1: c:/ win98 | d:/ win 2k/xp (where os's will be)
2: e:/
3: f:/
4 g:/
linux:
drive#
1: c: windows 98/2k/xp | hda2 (<? not a linux guy) /linux
2: d:/
3: e:/
4: f:/
note in 2k and xp you can change all drive letters but c:/
--Jacob--
JacobM5727 is offline   Reply With Quote
Old November 8th, 2002, 02:31 AM     #4 (permalink)
im gonna try using 2k and xp or maybe 2k and 98 or 98 and xp gotta get 2k or xp first though
Old November 8th, 2002, 07:30 AM     #5 (permalink)
RustyGT's Avatar
Zidane,
Sounds like you have quite a bit going on there.
If you only have 98 then install that first.
Get your comp going again.
Have a look at some of the earlier threads in Opps and Aps at TIMO regarding Dual boot systems.
Good Luck ChrsR.
RustyGT is offline   Reply With Quote
Old November 9th, 2002, 09:54 AM     #6 (permalink)
Make a 98 bootdisk then do a fdisk reformat on the partition you want to be your c drive then install the oldest system . you must install windows systems in the order they were released in. An example if you install xp first and then install 98 xp will be inacessable because 98 overwrites some files on the c drive. your boot. ini file is kept on your c drive so no matter where you install another os it always looks at the c drive first. If there is a college near you check their book store for the windows 2000 professional book, it must be the acedemic learning series, it contains a 120 day evaluation copy of windows 2000 pro. After 120 days if you are still learning just reinstall. Also 2000 server comes with a copy of server as well. I'm sure xp is the same. Some of the cdroms are mislabled though, the student cd rom is actually the os and the os is the student ( book on cd rom) also some of the newer ones are not bootable in which case you just surf the cd and make the four bootdisks.
whitebeard
whitebeard is offline   Reply With Quote
Would you vote for a gay politician.. (8)
Is It Just Me? (934)
Study: Majority Of Americans Out Of.. (10)
Broken Hard Drive (7)
new case and still a werid buzzing .. (8)
[ F@H Chat] 03/07/10 New Month New.. (47)
Need help looking for video card (10)
Using two fan connectors for one fa.. (9)
The end of XP is Nigh! (13)
YOUR BEST TRICK OR TIP FOR YOUR COM.. (12)
Primary Master Drive Fails (9)
RAM not fully used (22)
Best Graphics Card? (7)
cpu overclock (6)
Launching certain games crashes my wh.. (3)
Best cpu coolers on the market 2010 (2)
WTB/WTF a few things (2)
VIDEO CARD SUGGESTIONS (2)
Looking for a great free Disk Burning.. (7)
Wireless connection randomly disconne.. (2)
[ F@H Chat] 03/07/10 New Month New T.. (47)
YAMAHA 5.1-Channel Digital Home Theat.. (0)
Diagnostic Tools (11)
Amazon Lightning Deal at 12 PM PST - .. (0)
TechIMO Signature Policy Update (35)
diagnostic software?? (1)
Sager NP9262 Vista System Lockups; Wi.. (0)
My microphone is not working on my de.. (4)
Do I need to buy a Sony Video Link Mo.. (2)
Java - Need help ASAP (0)
Having trouble remembering a song tit.. (0)
unable to use dvd shrink (3)
Computer won't turn on (2)
is this the correct optical cable? (11)
new case and still a werid buzzing no.. (8)
Hp s3707c just hangs at HP boot scree.. (0)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (12)
Best Prevention of Fake AntiVirus Pro.. (13)
