Quick question.  | | |
November 9th, 2002, 05:01 PM
I'm about get my sisters comp together.
specs:
1 gig TBird
256 SDRAM
30 gig HD
I've installed winxp on that set up once in the past and it was a little slow but it still works, what i was wondering is if i should ust stick with win98se on that setup? any opinions?
aznlurkerz
i9300, lovin it!
November 9th, 2002, 05:03 PM
| | Determined Member
Naw, stick with XP. It will be more stable than 98. 98SE works well for about 6 months, but after that it gets so bloated and corrupted, it needs a fresh load.
-RADAR |
November 9th, 2002, 05:26 PM
| | the *Voice* in your Head
actually, it's quite the reverse, judging from all the posts around here.
seems like after 6+months, many xp systems need to be reinstalled. i had a win98 box for over 3 years that ran fine and i had tons of crap on it. the thing that did that machine in, was a d*mn aol upgrade...completely hosed the OS.
i do agree though that an xp box won't need to be rebooted as often  |
November 9th, 2002, 06:04 PM
oOo 2 different answers =P |
November 10th, 2002, 02:02 PM
| | Uncommon Man
I'd just go with Win98 if you've already got it.
It would run much faster on that box, IMO.
Sam |
November 10th, 2002, 02:19 PM
Just go with whatever you prefer, ask your sis whether she wants 98se or XP. If XP runs unusually slow on that comp (runs fine for me on a Duron 770 with 256mb of RAM) then use 98 instead, if you know your way around win98 better, then use that. Personally, I would say XP, but that's 'cos I'm too used to it over win98 now.
_____
NuKeS
November 10th, 2002, 04:03 PM
I think i'll go with win98se since its accept almost all the "c*ap" u put in front of it, and that i've used win98se a bit longer then xp, so i can tell that win98se will run a bit smoother, after the installation i just need to tweak the os a bit.
thanks all. |
November 10th, 2002, 04:17 PM
| | Si vis pacem, para bellum
I wouldn't do 98, but I am still partial to Win 2000 on my systems. I use it on all of mine, and they range from a 1.2GHz, a dual 750 MHz and a 266MHz.
It has the stability of XP and the low overhead and configurability of 98 (compared to XP)
(I know configurability isn't a word, but I don't care.  ) |
November 11th, 2002, 05:35 PM
lolz, i might just give win2k a try. I havent used win2k for more then a week, must i have to download all the service packs? what is it i need to d/l to get everything running smoothly, cause i've heard the fresh copy of win2k has alot of incompatabilities with software and hardware.
aznlurkerz |
November 11th, 2002, 05:43 PM
| | Go back to sleep
| Quote: Originally posted by aznlurkerz lolz, i might just give win2k a try. I havent used win2k for more then a week, must i have to download all the service packs? what is it i need to d/l to get everything running smoothly, cause i've heard the fresh copy of win2k has alot of incompatabilities with software and hardware.
aznlurkerz | no win2k is bad you cant play on it (if your sister plays )
and i don't like it winxp is the best one for playing and BTW you can change the design in winxp to a normal win98 that's perfect
Creatures
__________________ Canon EOS 450D | Canon EF-S 18-55mm 1:3.5-5.6 IS | Canon EF-S 55-250mm 1:4-5.6 IS | Canon Speedlite 430EX II |
