Replacement vga monitor cable.
Currently Active Users: 1448
Discussions: 204,479, Posts: 2,419,002, Members: 249,898
Old November 13th, 2002, 01:54 PM     #11 (permalink)
DutchMaster's Avatar
Just check which pin (on the sub-D15 connector) goes to which solderpoint on the board. Write it down. Then check which wirecolor represents a pin on the new cable. Just double check to be sure and if your handy with soldering, it would be an easy job and saves you allot of money.
Check the pin-out here: http://www.vpi.us/technote.html
Edit: offcourse you need a multimeter or Ohmmeter to check which pin goes to which solderconnection
DutchMaster is offline   Reply With Quote
Old November 16th, 2002, 09:38 PM     #12 (permalink)
Get one from your local Maplin for about a fiver. If its hardwired, then tough pish
Nickey is offline   Reply With Quote
Old November 16th, 2002, 10:13 PM     #13 (permalink)
Gyro's Avatar
If its hald wired I'd say your hosed. I would not attempt to repair monitors. If you need to salvage the monitor, then have a pro do it. (Unless you are a pro)
R/
Gyro
Gyro is offline   Reply With Quote
would this build be enough for WOW? (13)
The Local Weather Thread (695)
Is It Just Me? (1500)
Fighting Utility Companies (12)
Motherboard the culprit? (5)
Suggestions? (5)
Recent Problem (7)
I need help Guess what happened to .. (5)
Can't Rename Files (11)
[ F@H Chat] 03/07/10 New Month New.. (87)
Need some suggestions on building a.. (21)
My PC shutsdown after 30 minutes of.. (5)
Drive 0 not found: Serial ATA, Sata.. (7)
Compaq presario V5000 LAN Driver (8)
[ F@H Chat] 03/07/10 New Month New T.. (87)
Want a new power supply for my Dell. (32)
Suggestions? (5)
Drive 0 not found: Serial ATA, Sata-0 (7)
Recent Problem (7)
3D Pinball for Windows High Score (122)
mac noob in need of help please (0)
Hard drive full = slower computer? Is.. (4)
Processor speeds? (19)
Clean up safe to delete? (4)
Where to buy 3Rsystem Iceage 120 Boss.. (3)
Need some suggestions on building a g.. (21)
2.6.12, Linux kernel (3)
I need help Guess what happened to my.. (5)
Can 2 cards run off 1 pcie 16 slot (2)
Microsoft removes hardware virtualiza.. (0)
Screen Flickers @ Bios, Waves at Desk.. (0)
Writing lead-out (6)
Broken PaperPort 10 Link (5)
Windows XP Pro Error log (4)
Lost Password - Win7 (8)
YOUR BEST TRICK OR TIP FOR YOUR COMPU.. (19)
Help (1)
