Replacement vga monitor cable.  | | |
November 13th, 2002, 01:39 PM
Hi all. Just need to know where to buy a new vga cable for my monitor. Dog got the best of it and I'm missing blue now  Where's a good place to pick one up? |
November 13th, 2002, 02:03 PM
| | Thaumaturge Member
I don't know if they're a standard item. You may have to get one from the manufacturer. Of course, you could try the local thrift shop and see if you can find a cheap old monitor of the same brand. BTW, can you read this? hehe |
November 13th, 2002, 02:10 PM
Hehe yeah I can read it. I'm on a different machine atm  I didn't even think about taking one from another monitor. I might just have one laying around. Will have to take a look. |
November 13th, 2002, 02:11 PM
| | Banned
I had to get mine from the manufacturer of the monitor, it cost something like $40.
*edit* I tried one from a different monitor and the pinout was not the same. |
November 13th, 2002, 02:16 PM
| | Thaumaturge Member
What kind of monitor is it (brand/model)? |
November 13th, 2002, 02:22 PM
gc:
Try www.cablesonline.com . I'm sure if it's a 15 - pin D-sub standard VGA cable, they will have one for a lot less than $40.
A lot of them are connected inside the monitor itself ; if so, that
might get tricky. . .be careful.
- Bill |
It's a Phillips / Magnavox 17". MB7000 manufactured in 1997. Anybody know if they make a replacement connector for the end of the cable? I could just cut about a foot off too. |
November 13th, 2002, 02:26 PM
November 13th, 2002, 02:29 PM
| | Thaumaturge Member
You'd have to know what color wire goes with what pin. The color coding is probably not the same. |
November 13th, 2002, 02:47 PM
I've got several. If interested, I can take a pic of the connectors to see it matches yours. |
