The awful grinding....
Currently Active Users: 1593
Discussions: 200,505, Posts: 2,374,392, Members: 245,829
Old November 23rd, 2002, 09:22 PM   Digg it!   #1 (permalink)
agathodaimon's Avatar
Is it normal for a hard drive to make an awfully loud grinding noise as I am playing a game, or loading documents, etc..?
It's a Maxtor 40-Gig ATA 133 7200 RPM.
Don't know the exact model number at the moment.
But sometimes it's worse than others. Some days, i'll be playing Everquest and it'll run smooth as silk, and you can hardly hear the thing run. Some days, all it does is make that terrible grinding/whirring noise and it's slow as heck.
Right now, i'm virus scanning, and all i hear is crekkcckeekcckekcke. if that description is adequate.. hehe
Is there something wrong with it? Or is it normal?
agathodaimon is offline   Reply With Quote
Old November 23rd, 2002, 09:38 PM     #2 (permalink)
Steeler Fan
jman01pa's Avatar
That is not normal. It is possible it could work fine that away for a long time, but i doubt it. If it was me, I would copy my important stuff off and send it in to Maxtor under warranty. They generally have a really quick turn around time. I am talking like just a few days from when they recieve it. The last one I sent in i got back in less than a week.
Also realize that you wont get the same one back, so make sure there is nothing you cant lose. They will send you the same model or possibly even a higher model back. I sent in a 20 GB a few months ago and got back a 30 GB. I was happy.
jman01pa is offline   Reply With Quote
Old November 23rd, 2002, 09:40 PM     #3 (permalink)
Steeler Fan
jman01pa's Avatar
FYI
Maxtor Warranty Support
1-800-2-MAXTOR
(1-800-262-9867)
More Info
http://www.maxtor.com/en/support/ser...rranty_ata.htm
Old November 23rd, 2002, 10:35 PM     #4 (permalink)
eclipsera's Avatar
Send a message via AIM to eclipsera
for that speed, and make of hdd no way is that normal. contact them ASAP dude.
GA-7VAXP Ultra
WD 180GB 7200RPM
Razer Diamondback
SyncMaster 710T
GF FX 5900 Ultra
512MB RAM
Athlon XP 2000+ @ 1850Mhz
Corsair HydroCool 200 EX
eclipsera is offline   Reply With Quote
Old November 23rd, 2002, 10:44 PM     #5 (permalink)
davidamarkley's Avatar
Send a message via ICQ to davidamarkley Send a message via AIM to davidamarkley
Yeah, I had one that made that kind of noise and went out within a month...
It just depends, but I would return it to Maxtor. They normally have pretty great drives but every now and then you get a bad egg. Backup everything that is needed and send it to them ASAP. And, you normally don't get the same actual drive back, but it will at least be what you had if not better!
David
davidamarkley is offline   Reply With Quote
Old November 24th, 2002, 12:03 AM     #6 (permalink)
chris64's Avatar
I had a harddrive which had the same prob and it was doing it for a couple years and you know what I never took the time to back it up, and I knew about the problem but I guess I was just lucky it didn't break down and probably a little stupid. Don't worry I just got a new harddrive a few months ago and will start backing up(when I find the time).
chris64 is offline   Reply With Quote
Old November 24th, 2002, 12:44 PM     #7 (permalink)
cool, thanks guys!
I guess I'll be backing up my data and getting a hold of Maxtor.
It's just kinda irritating to have a HD that's only several months old do this to me.
Old November 24th, 2002, 01:41 PM     #8 (permalink)
ok, i took my Hard drive out to write down the numbers & such.
It is the model : D740X-6L
But anyways, as i took it out and set it aside, i heard something rattling around inside of it.
I REALLY don't know if that's normal or not. Certainly doesn't seem like it should be.
Do you think i should bother with the powermax disk check utility Maxtor has on their website first?
Old November 24th, 2002, 01:51 PM     #9 (permalink)
HotRod9mm's Avatar
Send a message via ICQ to HotRod9mm
Unhappy
Not good.....
I have the same model and it lasted about 2 months before heading south. So I need to request an RMA. A friend has 2 of them and has RMA'ed them 3 times(1-twice/1-once)........
Blaming firearms for violence is like blaming spoons for Rosie O’Donnell for being fat!
HotRod9mm is offline   Reply With Quote
Old November 24th, 2002, 02:36 PM     #10 (permalink)
Leader of the Crab People
Redwolf's Avatar
Send a message via ICQ to Redwolf Send a message via AIM to Redwolf Send a message via Yahoo to Redwolf
If the hard drive is making that noise, send it back (RMA it).
Sometimes (usually), it's a fan making grinding noises, but when it's a fan it happpens as soon as you start up the computer.
Redwolf is offline   Reply With Quote
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
