Formatting CDRW
Currently Active Users: 2154
Discussions: 200,947, Posts: 2,379,379, Members: 246,307
Old November 28th, 2002, 06:53 PM   Digg it!   #1 (permalink)
mad1's Avatar
Formatting CDRW
I have been unable to format a CDRW. I go to the drive thru my computer and right click on the drive, there is no option to format the disk. I have tried this on WIN 2k and now tried it on XP Pro with the same results, do I need a seperate progrma to do this?
mad1 is offline   Reply With Quote
Old November 28th, 2002, 06:57 PM     #2 (permalink)
Not Really a Member
what software do you have installed ?
Either Nero or Adaptec EZ CD Creator (or many others) can do it...
If you're on XP I think you can do it, but not sure why you can't do it... assuming you're using a cdrw drive of course
vass0922 is offline   Reply With Quote
Old November 28th, 2002, 07:02 PM     #3 (permalink)
thekemp's Avatar
you need either adaptec direct cd or aheads INCD they are both similar if you own nero you can either install incd from the nero disk or download it from www.ahead.de for free .
then you can format the disks and use them like a floppy
thekemp is offline   Reply With Quote
Old November 28th, 2002, 07:51 PM     #4 (permalink)
tekmonkey's Avatar
or there is software called DLA as well
Just my 2 cents.
tekmonkey is offline   Reply With Quote
Old November 28th, 2002, 07:55 PM     #5 (permalink)
mad1's Avatar
Can someone tell me how to do this using Easy CD creator or Direct Cd Version 4,running win XP?
Old November 28th, 2002, 07:55 PM     #6 (permalink)
shahani
Posts: n/a
Yes, DLA is also the same as InCD or Direct CD. DLA=Drive Letter Access--basically with this software installed you see the CDRW/DVDRW disks as a giant floppy and can read/write on the fly.
DLA is a propriatory HP software and comes with HP DVD RW drives.
Old November 28th, 2002, 07:57 PM     #7 (permalink)
shahani
Posts: n/a
Version 4 won't work with XP. Go to www.roxio.com and check the upgrades. Even the 5.X version will not work with XP unless you do the updates available free on their site.
Old November 28th, 2002, 08:00 PM     #8 (permalink)
shahani
Posts: n/a
mad1, I'd suggest you get the version 5 if you already own the version 4. The Version 5 of EasyCD Creator Platinum is compatible with XP with the updates installed. And the upgrade form version 4 to version 5 is not expensive. In fact sometimes if you search you can get it for under $30 but for that money you can also buy a new CD burner and get the latest version of EasyCD or Nero bundled. So maybe it's better to get a new drive just to get the software. The Nero package is excellent.
Making Health Care Worse (167)
The disrespect of Obama by Russian .. (19)
Is It Just Me? (2932)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
