PLEASE HELP!! Cursor Control (or Un-control)
Currently Active Users: 1816
Discussions: 200,933, Posts: 2,379,198, Members: 246,298
Old December 7th, 2002, 10:18 AM   Digg it!   #1 (permalink)
Send a message via Yahoo to sk8er475
Angry
Guys,
hope u can help!!!
I'm running Win98, Athlon 1.2Ghz processor, 20Gb & 128mb
Every now and again (though getting more frequent).....my mouse cursor goes haywire all over the screen and i'm unable to control it.......programs and applications open of their own accord and the only way out is to reset the pc.
The problem is intermittent, but becoming very annoying.
Your advice/opinions would be greatly appreciated.
Many Thanks
D.
sk8er475 is offline   Reply With Quote
Old December 7th, 2002, 10:22 AM     #2 (permalink)
mlee97's Avatar
Get a new mouse, your mouse cable is bad (Probably)
I've seen this before... IRQ conflic used to do that on old machines but know it's usually a bad mouse cable.
mlee97 is offline   Reply With Quote
Old December 8th, 2002, 08:06 PM     #3 (permalink)
Ordained Mommy
NeoStarO1's Avatar
not neccarly, could be the mouse accerlatoer is set too high. that can cause the mouse cursor to go everywhere. that can be tested and changed via control panel > mouse.
sk8er475 what kind of mouse do you have?
NeoStarO1 is offline   Reply With Quote
Old December 15th, 2002, 04:35 PM     #4 (permalink)
Neo,
Have checked the mouse speed and seems to be ok, (well set at medium)......have got a really cheap and nasty mouse though...Safeway SW3D?????.......never heard of it..nor me....
I think a new mouse could be in order anyway......
Old December 17th, 2002, 03:08 PM     #5 (permalink)
pc_dr.j's Avatar
Hmm... before buying a new mouse have you tried cleaning it first? You see mouse `jerky' `movements are usually caused by dust debris accumulating inside your mouse causing havoc in the sensor rollers in your mouse; this in turn affects your mouse's performance.
I suggest cleaning your mouse first. Remove the ball from your mouse, clean it then look inside your mouse. Remove the dirt and debris that's accumulated in your mouse rollers (A cotton swab dipped in denatured alcohol will do). Oh yeah and clean your mousepad too Soap and water will do the trick.
Now if you're in the mood for buying a new mouse, it's up to you. Hope this helps
Thanks for the reply; sorry if I can't answer quickly :)
pc_dr.j is offline   Reply With Quote
Old December 17th, 2002, 09:21 PM     #6 (permalink)
Bopper's Avatar
Also the second payload of the magistr virus causes the Icons on your desktop to run awayfromthe mouse pointer. probably not this particular virus, but maybe you have aqcuired a virus that is causing this behavior. does it do it all the time? does it do it in safe mode?
After one look at this planet any visitor from outer space would say "I want to see the manager."
William S. Burroughs (1914 - 1997)
Bopper is offline   Reply With Quote
Old December 17th, 2002, 09:39 PM     #7 (permalink)
OH NO!
Brainchild's Avatar
Send a message via Yahoo to Brainchild
Prolly a mouse on the rampage, taht what is was when mine did that
BC
Brainchild is offline   Reply With Quote
Old December 21st, 2002, 05:34 PM     #8 (permalink)
Thanks for yr comments guys,..........have cleaned and virus checked & all ok........i'm gonna go with the dodgy mouse idea.......
new mouse it is........
Will keep u posted
Thanks again..........D.
Is It Just Me? (2889)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
