PSU power needed  | |
December 25th, 2002, 01:44 PM
I have an OK system right now, and I am slowly upgrading. The first thing I am getting is a power supply. I don't know if a 350W will be enough. A 400w and 430w are a lot more, so I hope 350w will be enough.
System: (hope this is everything)
MSI 6330 ver2.1 (bought in '01)
AMD Athlon T-Bird 1.1 Ghz w/ Retail Fan
1x 40GB Fireball HD
1x 1GB WD HD
256MB 133mhz SDRAM
LeadTek GeForce 4 4400
Toshiba DVD-ROM
Lite-On 40x CD-RW
Floppy
Creative Sound Blaster Live
56k Modem
USB mouse and Game pad
After upgrading I will change:
CPU ~ Athlon XP 2400+
RAM = 512MB PC 2700 Corsair
MOBO=Soyo Dragon Ultra KT400
I know a 350w can handle what I have now, but will it do okay after upgrading? Considering I am running everything I have now on a 250w...
Thanks....Merry Christmas |
December 25th, 2002, 02:04 PM
IMO, 350W would be plenty for what you're talking about. BUT, more is always better!  Just make sure you get a good quality PSU. Cheap PSU's often don't put out the wattage that they advertise. A good PSU that's rated at 350W will put out at least that, probably a bit more. Plus, a good PSU is better at giving good "clean" power. In other words, it'll give you steady 115V even if you have a voltage spike or drop. Hope this helps. Merry Christmas!  |
December 25th, 2002, 02:06 PM
Oh yea, I'm buying an Antec SmartPower 350w. I heard good stuff about Antec, and Enermax is more $$. Cool, I'm buying it right now.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
December 25th, 2002, 02:28 PM
Sounds good. I'm using an Enermax 431W. Got a good deal on the Antec? Where you getting it from? How much? |
December 25th, 2002, 08:53 PM
I think you'll be fine with the 350... |
December 25th, 2002, 10:20 PM
Newegg. I got the 350 for $47, $53 shipped. Was at Best buy toda, they wanted the EXACT same PSU for 64.99 plus tax! |
December 25th, 2002, 11:05 PM
Yep, 350 will more that fit your needs. A good Antec or Enermax would fill the bill nicely.
Mike
__________________ SimplyMepis 8.0. . . Kernel-2.6.27-1-mepis64-smp |
