Help Deciding
View Poll Results: Should I Reinitialize ?
Yes 1 25.00%
No 3 75.00%
Voters: 4. You may not vote on this poll
Currently Active Users: 2400
Discussions: 200,942, Posts: 2,379,323, Members: 246,305
Old December 29th, 2002, 10:39 PM   Digg it!   #1 (permalink)
uncle_jimbo's Avatar
Send a message via AIM to uncle_jimbo
Help Deciding
I cant decide weither or not to reinitialize my HDD after I swap the CPU, what do you think I should do ?
uncle_jimbo is offline   Reply With Quote
Old December 29th, 2002, 10:40 PM     #2 (permalink)
Mean Moderator
EvilRick's Avatar
If you're talking about just upgrading the CPU, why would you need to reinitialize the HDD?
EvilRick is offline   Reply With Quote
Old December 29th, 2002, 10:43 PM     #3 (permalink)
Wizzard~Of~Ozz's Avatar
Send a message via ICQ to Wizzard~Of~Ozz Send a message via MSN to Wizzard~Of~Ozz
???? Re-initialize you HDD? I don't even know how you would do that let alone what it is, just swap the CPU, no OS or other hardware will care.
Wizzard~Of~Ozz is offline   Reply With Quote
Old December 29th, 2002, 10:43 PM     #4 (permalink)
Im not really sure why. Perhaps Ill just defragment the HDD.
Old December 29th, 2002, 10:44 PM     #5 (permalink)
Mean Moderator
EvilRick's Avatar
Good idea.
Old December 30th, 2002, 01:26 AM     #6 (permalink)
Send a message via AIM to RamonGTP Send a message via MSN to RamonGTP Send a message via Yahoo to RamonGTP
Does reinitilize = reformat??? If so, you shouldn't need to do that for a CPU upgrade... A motherboard upgrade maybe, but you should be ok just swapping out the cpu's.
RamonGTP is online now   Reply With Quote
Old December 30th, 2002, 01:29 AM     #7 (permalink)
Ok, thanks.
The disrespect of Obama by Russian .. (14)
Making Health Care Worse (155)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
