Athlon Clock speed graph
Currently Active Users: 1525
Discussions: 200,953, Posts: 2,379,483, Members: 246,321
Old January 5th, 2003, 02:49 AM   Digg it!   #1 (permalink)
joker_927's Avatar
You would think a simple graph like this would be easy to find. Well, I couldn't find anything like it even on the AMD website. So I set out and made my own! I couldn't find out if the 2400+ was 1.93 ghz or 2.0ghz. For those of you wondering the same thing (probalby very few), that's where the throughbred RevB comes in. the 2500+ was SUPPOSED to 1.93 but AMD made a little revision and upped it by 66mhz (along with the 2600+) in order to compensate for their weird numbering.
Hope this helps someone, helped me a lot.
Athlon XP Clock Speeds
CPU Name Clock Speed
Athlon XP 2600+ 2.13GHz <---throughbred RevB
Athlon XP 2400+ 2.00GHz <---throughbred RevB
Athlon XP 2200+ 1.80GHz
Athlon XP 2100+ 1.73GHz
Athlon XP 2000+ 1.67GHz
Athlon XP 1900+ 1.60GHz
Athlon XP 1800+ 1.53GHz
Athlon XP 1700+ 1.47GHz
Athlon XP 1600+ 1.40GHz
Athlon XP 1500+ 1.33GHz
joker_927 is offline   Reply With Quote
Old January 5th, 2003, 04:42 AM     #2 (permalink)
Tekk's Avatar
Any information is good information (well not always but in this case its knowledge!) Thanks!
YAH! I knew you'd be jealous
Tekk is offline   Reply With Quote
Old January 5th, 2003, 05:20 AM     #3 (permalink)
Idigguns's Avatar
Send a message via AIM to Idigguns
All you had to do is ask! I have a chart like that already made up.
Idigguns is offline   Reply With Quote
Old January 5th, 2003, 01:20 PM     #4 (permalink)
ryogenetic's Avatar
I have the AMD XP 2400+ in my sys. Its on a MSI board and the controller that MSI puts in the K7 Ultra throttles the 2400+ sometimes it is running @ 1.93 and others 2.01. Not sure if the XP has some sort of power now like in the laptop version or not.
Ryo
Ryo
ryogenetic is offline   Reply With Quote
Old January 5th, 2003, 01:24 PM     #5 (permalink)
Master Chief's Avatar
Send a message via AIM to Master Chief Send a message via Yahoo to Master Chief
Nice job Joker.
Master Chief is offline   Reply With Quote
Old January 5th, 2003, 01:50 PM     #6 (permalink)
AuraEdge's Avatar
Send a message via ICQ to AuraEdge
Chart
It's the same one though, just proves your correct.
Also for completeness sake, theres also
Athlon XP 2700+ at 2.17Ghz
Athlon XP 2800+ at 2.25Ghz
These both run at 166Mhz FSB.
The 2700+ is out there already, and I think the 2800+ is going in stores this week.
AuraEdge is offline   Reply With Quote
Old January 5th, 2003, 01:54 PM     #7 (permalink)
joker_927's Avatar
Doh! Guess I didn't see that one. Well, Iat least I accomplished something. I just hope my 2400+ gets recognized as 2.13 and not 1.93 ghz. I guss it doesn't matter sinse I will be o/c it right out of the box.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
Old January 5th, 2003, 02:12 PM     #8 (permalink)
Idigguns's Avatar
This is the one I use, it's from AMD's web site.
General AMD Athlon XP Model 6 Processor ("Palomino") Specifications
Model Number| Operating Frequency| Voltage Max | Die Temperature | Front-Side Bus
1500+ | 1333 | 1.75V | 90º Celsius | 266
1600+ | 1400 | | |
1700+ | 1467 | | |
1800+ | 1533 | | |
1900+ | 1600 | | |
2000+ | 1667 | | |
2100+ | 1733 | | |
General AMD Athlon XP Model 8 Processor ("Thoroughbred") Specifications
1700+ | 1467 | 1.50V | 90º Celsius | 266
1800+ | 1533 | | |
1900+ | 1600 | | |
2000+ | 1667 | 1.60/1.65V1 | |
2100+ | 1733 | 1.60V | |
2200+ | 1800 | 1.60/1.65V1 | 85º Celsius |
2400+ | 2000 | | |
2600+ | 2133 | 1.65V | | 266/333
2700+ | 2167 | | | 333
Notes:
1. Refer to the processor's OPN for the proper operating voltage.
2. Refer to the processor's OPN for the proper FSB frequency.
*EDIT: I should've known that wouldn't display right!
Old February 16th, 2003, 09:17 PM     #9 (permalink)
The Punisher's Avatar
Send a message via AIM to The Punisher
yes that helps me out a lot..i was just curious..about the xxxx numbers...cuz they're not the actual speeds.
The Punisher is offline   Reply With Quote
Old February 16th, 2003, 09:46 PM     #10 (permalink)
Cruizing
Chart including the Barton
Athlon XP 3000+..... (Barton) 2.167GHz
Athlon XP 2800+..... (Barton) 2.083GHz
Athlon XP 2800+..... (333MHz FSB) 2.25GHz
Athlon XP 2700+..... (333MHz FSB) 2.167GHz
Athlon XP 2600+..... (333MHz FSB) 2.083GHz
Athlon XP 2600+..... 2.13GHz
Athlon XP 2500+..... (Barton) 1.83GHz
Athlon XP 2400+..... 2.00GHz
Athlon XP 2200+..... 1.80GHz
Athlon XP 2100+..... 1.73GHz
Athlon XP 2000+..... 1.67GHz
Athlon XP 1900+..... 1.60GHz
Athlon XP 1800+..... 1.53GHz
Athlon XP 1700+..... 1.47GHz
Athlon XP 1600+..... 1.40GHz
Athlon XP 1500+..... 1.33GHz
VERT is offline   Reply With Quote
Is It Just Me? (2943)
Print spooler problem (15)
Dept. of HS: NSA 'Helped' Develop V.. (16)
SELLING FRESH,CVV,LOGINS,DUMPS,TRACKS.. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
