Help me build my first computer: Parts..  | | |
January 11th, 2003, 06:13 PM
| | Banned
January 11th, 2003, 06:46 PM
Hi there iNeb,
You are on an adventure that will work well because of all of the knowledgeble people here....
Ask a mod to put ur thread here as a sticky thread so you can depend on help every step of the way.
Sorry I can't help ya wit da stuff ya got BUT, you are in the right spot to get info from peeps who have done it.....
Good Luck to ya...
((((and thank you bub, I tink my comment, as worthless as it is, may be da one that lets me have an avatar....special dude, iNeb, thks!!!) |
January 11th, 2003, 06:49 PM
that should work. sorry, i cant find that keyboard. maybe someone else can. but, yeah, i think that looks ok  |
January 11th, 2003, 06:57 PM
Sounds like you've pretty much got it covered. The only change I would make, is to drop the WD drive and go for a Maxtor.  |
January 11th, 2003, 07:09 PM
| | Perfetc Member
Hmm, Ive had pretty bad luck with Maxtor hard drives. A slightly higher heatsink wouldnt hurt, especially if you plan to overclock. Thats also the ugliest computer case I've ever seen, but its all up to you. Sounds like you are definately on the right track. |
January 11th, 2003, 07:11 PM
| | Perfetc Member
Err ignore the comment about the case, looked at the wrong picture set =( |
January 11th, 2003, 07:52 PM
For the keyboard try going to http://www.tigerdirect.com
Last time I checked they had it, but they also have many other ones. I would definatly go with the WD hard drive, but even better would be an IBM HD if you can get one. In my opion Maxtors are not wery good, as I have had several fail on me.
Also for the WD drive, try using tiger OR going to the WD website. Last time I checked they had a similar hard drive (6o GB, 7200 RPM) |
January 11th, 2003, 09:19 PM
| | Leader of the Crab People
HArd Drive:
IBM-They have good drives, but DON'T get a 60 or 75 series drive. They have bad prolems.
Fujitsu-Have had major problems lately, don't buy from them.
Hitachi-Smae drives as IBM.
Western Digital-Rebutable company, good drives. Never heard of an RMA from them.
Maxtor-Drives haven't been the greatest, but they have a great RMA service.
Seagate-HAve an 80 GB Barracuda from them now. Works fines, but I haven't had much experience with them lately.
I reccomend Western Digital.
If you have an old floppy drive, just use that. Floppys today aren't any diffrent from ones in 1990. Saves $10. |
January 12th, 2003, 01:56 AM
| | Banned
| http://www.techimo.com/forum/t48021.html
I'm getting two of these tomorrow, as me and my step dad are building pcs together..
I'll post his parts later on.. http://freewebspace.net/forums/showt...threadid=38865
What about these comments?
"And don't get the Epox board as it uses Via KT400 chipset(It wont work with your SB 5.1 soundcard). Get an Nforce2 + 2600+(333mhz FSB)+ PC2700 RAM and your system will kick ---." and so on..
VHockey, what case were you looking at? |
January 12th, 2003, 02:02 AM
Looks good, but go ahead and get a better heatsink. AMDs run hot. Dont' scimp on the heatsink.
Pete
