TechIMO shortcut keys
Currently Active Users: 1166
Discussions: 200,929, Posts: 2,379,147, Members: 246,296
Old February 5th, 2003, 05:36 AM   Digg it!   #1 (permalink)
Cruizing
I noticed the other day by mistake that "ALT S" is a shortcut for submit (I always hit ALT S to submit an ICQ message). Does anybody know of any other shortcuts for this forum?
VERT is offline   Reply With Quote
Old February 5th, 2003, 02:26 PM     #2 (permalink)
Cruizing
you sure about that, those keys you suggest just play with my IE settings such as closing a window, opening history and organising favourites.
Old February 5th, 2003, 05:08 PM     #3 (permalink)
Go back to sleep
Creatures's Avatar
Send a message via ICQ to Creatures
it doesnt work with Opera and i dont want to use IE (ugh)
Creatures
Canon EOS 450D | Canon EF-S 18-55mm 1:3.5-5.6 IS | Canon EF-S 55-250mm 1:4-5.6 IS | Canon Speedlite 430EX II
Creatures is offline   Reply With Quote
Old February 6th, 2003, 03:22 AM     #4 (permalink)
Cruizing
Creatures
dont blame ya
Old February 6th, 2003, 03:27 AM     #5 (permalink)
Rather Large Member
Beemer's Avatar
Send a message via MSN to Beemer
For submit I just hit Tab then Enter keys after I finished typing.
The same with ICQ. Let your pinkies do the walking.
Cheers! (tab enter)
Beemer is offline   Reply With Quote
Old February 7th, 2003, 02:40 AM     #6 (permalink)
Cruizing
Cheers! (tab enter)
thats what I used to do because of ICQ as well, but now that I use ICQ Lite you cannot do this, but instead ALT S is the one
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
