RAM Problem
Currently Active Users: 2101
Discussions: 200,948, Posts: 2,379,405, Members: 246,309
Old February 17th, 2003, 05:33 PM   Digg it!   #1 (permalink)
RAM Problem
Hello, I am putting together a new computer and I encountered a problem. Everything is running ok, but when I tried to check how much RAM I had (right click my computer, system properties), it said that I only had 128MB of RAM. However, I installed a 256MB DDR RAM. What did I do wrong?
Thanks in advanced!
localboy2332 is offline   Reply With Quote
Old February 17th, 2003, 05:42 PM     #2 (permalink)
vicarious george's Avatar
Whenever you ask questions of this type, be sure to include system specs. (i.e. mobo model, CPU, PSU, RAM brand, etc...) It makes it much easier for us to help.
vicarious george is offline   Reply With Quote
Old February 17th, 2003, 05:52 PM     #3 (permalink)
Ok, I'm sorry. I have a MSI K7T226 Pro2 ver.2 motherboard, an Athalon XP 1800 CPU, and have a 98SE OS. I don't know the manufacturer of my RAM. All it says is 256M-DDR, MD AE128M DDR-7, PC266, 0218.
Old February 17th, 2003, 05:53 PM     #4 (permalink)
The Punisher's Avatar
Send a message via AIM to The Punisher
are they the same types of ram? as in you know the pc... pins..etc
The Punisher is offline   Reply With Quote
Old February 17th, 2003, 06:00 PM     #5 (permalink)
Yes they are.
Old February 17th, 2003, 06:18 PM     #6 (permalink)
desmocat's Avatar
One thing you might check is to see if the module is in the first memory slot.
I have an ABIT board that numbers the DIMM slots opposite, in that slot #1 is furthest away from the CPU socket, and It would only see 128 meg of a 256 meg module that I put in.
When I put it in the "real" #1 slot, the whole 256 would be recognized.
desmocat is offline   Reply With Quote
Old February 17th, 2003, 06:31 PM     #7 (permalink)
yea thats another thing sometimes the modules have to go in a certaini order..i have an asus mobo with four rimms...and they have to go in a certain order so check that
..or you might also have bad ram
Old February 17th, 2003, 08:48 PM     #8 (permalink)
Ok, I'll try that and let you know if it works. Thanks!
Old February 17th, 2003, 08:58 PM     #9 (permalink)
alright man no prob..
Making Health Care Worse (174)
Is It Just Me? (2937)
The disrespect of Obama by Russian .. (23)
Regular Build (6)
Print spooler problem (15)
Point and Shoot Camera Suggestions. (3)
How to convert MP3's (4)
Graphics Card Upgrade Question (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
