Thread: Optical & Mouse Pad
February 21st, 2003, 12:55 AM #1
Optical & Mouse Pad
hey yall. i have always used an optical mouse on my computer, but of course i have used balled mouses on others. i have never really noticed any bad performance from just using my optical mice on a plain table top, etc. my quesion is, would any or a certain type of mouse pad help or would it not make any difference?
drewVisit http://duroo.org
February 21st, 2003, 01:03 AM #2
Most of any help from a mousepad would be only in the easier gliding rather than better tracking. If you feel like your "sticking" too much to your table top, consider a good mouse pad. Otherwise, I dont think it will help you much. A cloth pad will probably make things worse, so theres no point to using one of those with an optical (IMO).
February 21st, 2003, 01:08 AM #3
The only thing I can remember my manual saying is that a dark surface will make it (mouse) use the batteries faster.
I keep about 500 or so "optical" mouse pads on hand, AKA- sheets of paper.
The only reason I do that is to keep the dirt/oil from my hands from making one side of the keyboard tray on my desk dingy looking. It's cheap too..
Edit>
If paragraph+syntax=fubar ;
and sleep time * = > 16 hrs ago;
jump to : bed.
end.Last edited by desmocat; February 21st, 2003 at 01:12 AM.
February 21st, 2003, 01:10 AM #4
On the other hand, I use a cloth type mouse pad with my optical mouse because optical mice tend to be "lighter" feeling to me than ball-type mice, so I like the slight amount of extra drag it provides.
Sam
February 21st, 2003, 07:49 AM #5Ultimate Member
- Mar 2002
- 1,511
Hi there, I also use Optical mice exclusively, and here is the mousepad I use... its so good, it'd be the last mousepad you will ever need.... its just that great.
Its the top left 2 on this page, my wife uses the smaller one.... she like me, will swear by it
http://www.frozencpu.com/cgi-bin/fro...u_search.htmlv
Good Luck!
Good Morning friends.. You have to watch following shows and movies on daily basis. Warehouse 13 Season 4 Episode 14 Bates Motel Episode 10 Regular Show Season 4 Episode 27 The Secret Life of...
Watch free online NOW
