dual booting
Currently Active Users: 1477
Discussions: 200,956, Posts: 2,379,485, Members: 246,317
Old February 28th, 2003, 10:49 PM   Digg it!   #1 (permalink)
Unhappy
dual booting
I am duel booting with me, advanced server and xp. I just loaded win 2000 pro and now I can't get into xp. All the other os's work fine. I tried the repairs that were on the site and they don't work. Me is on the c drive and xp on the d, 2000 is on the e drive and advanced server is on the f. They are all on there own partition but on the same hd. Anyone have any ideas?
ruz606 is offline   Reply With Quote
Old February 28th, 2003, 10:59 PM     #2 (permalink)
KenKun's Avatar
This is a knows problem happens because of installing win2k *after* winXP .. win2k will replace NTLDR with its own one and it will make winXP inaccessable ..
The solution is simple, just copy NTLDR and NTDETECT.COM files from your winXP CD back to the root directory of your boot drive (C: drive).
The files that you have to replace are hidden and protected system files, you have to change an option in your Explorer`s File option to show hidden protected system files before you can view and replace them.
All the above can be done while you`re in winME or win2k.
Welcome to TechIMO
Regards
Edit> also check this from M$
Cannot Start Windows XP After You Install Windows 2000
KenKun is offline   Reply With Quote
Is It Just Me? (2943)
Print spooler problem (15)
Some methods to retrieve lost Windows.. (0)
lost Windows user name and password (13)
whats the fastest dvd ripper? (13)
How to Convert Blu Ray Disc Movie to .. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
