Decoder card
Currently Active Users: 2131
Discussions: 200,919, Posts: 2,379,064, Members: 246,287
Old March 11th, 2003, 10:23 PM   Digg it!   #1 (permalink)
Decoder card
Ok funky question here.........If I buy a pci dvd decoder card, or some other product, would it be possible to run dvds on my other pc, a 333mhz P2 with 96 mb of ram? Just wondering
sccfreak is offline   Reply With Quote
Old March 11th, 2003, 10:29 PM     #2 (permalink)
XxCowOfChaosxX's Avatar
Send a message via AIM to XxCowOfChaosxX
u would also need a dvd-rom drive
XxCowOfChaosxX is offline   Reply With Quote
Old March 11th, 2003, 10:30 PM     #3 (permalink)
embj's Avatar
Send a message via AIM to embj Send a message via MSN to embj Send a message via Yahoo to embj
You will still need a DVD-ROM or DVD-RW. A DVD decoder card is just what you need to play the DVD's like I assume you already have some DVD-ROM because you said my "other" computer. To use a DVD-ROM to view DVD's you need decoder software like PowerDVD or a hardware DVD decoder. Anyway you still need a DVD-ROM. You just need a software or hardware DVD decoder so your computer can decipher the DVD's.
embj is offline   Reply With Quote
Old March 11th, 2003, 11:54 PM     #4 (permalink)
yeah I got a dvd drive. the reason i asked all this stuff is because the dvds won't play nicely at all just using software like WINDVD on that system, a hardware decoder card would enable me to watch them a lot better. Correct?
Old March 12th, 2003, 12:15 AM     #5 (permalink)
embj's Avatar
Yes, that is true. Hardware is better than software.
Is It Just Me? (2849)
Obama the Muslim (12)
Print spooler problem (12)
Display shows 3x5 inch in middle of s.. (2)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (33)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
