hp officejet scanner/printer glitch
Currently Active Users: 1609
Discussions: 200,509, Posts: 2,374,405, Members: 245,832
Old April 13th, 2003, 01:44 PM   Digg it!   #1 (permalink)
draboo's Avatar
Send a message via MSN to draboo Send a message via Skype™ to draboo
i have a hp officejet v40 printer/scanner/copier. i ve been thru all the available tests/alignments. the cartridges are around half full of ink. and it still prints with lines every quarter inch throughout the whole page.(see attachment)
any suggestions??
i m out of ideas
thanks,eh??
disgruntled brad
draboo is offline   Reply With Quote
Old April 13th, 2003, 01:48 PM     #2 (permalink)
Ordained Mommy
NeoStarO1's Avatar
I Had that happen with my HP 3in1. Turned out a thumbtack fell inside and was just hiding just right. Once I got that out it was fine.
Have you check to see nothing is making the rollers not stay put?
How long have you had the printer?
When was it last service? (you can tell here I don't service my own printers. )
NeoStarO1 is offline   Reply With Quote
Old April 13th, 2003, 01:50 PM     #3 (permalink)
Richard Cranium's Avatar
HP offers a free cleaning kit, I dunno if it'll help your issue, kinda looks like a scan problem to me..
Richard Cranium is offline   Reply With Quote
Old April 13th, 2003, 01:52 PM     #4 (permalink)
draboo's Avatar
hmm,neo,i ll have to check that out. with a couple of grandkiddys getting into whoknowswhat,its very possible something got in there. our resident snoopy cat Frank(enstien) could be behind it too.
its a real new printer,like 6 months old. i havent used it very much.
Old April 13th, 2003, 02:03 PM     #5 (permalink)
draboo's Avatar
the pic was printed out from a jpg file from hard drive.
then i scanned it and saved the image with the lines in it and posted it.
so the lines were there after the printing,but were not on the original jpg image.
i think................
Old April 13th, 2003, 02:03 PM     #6 (permalink)
Ordained Mommy
NeoStarO1's Avatar
Investigating on docs post this here is what I found.
HP All-in-One and Fax Products - Cleaning the HP All-in-One or Fax
Here is a quote of interst related to docs post if its a scanning problem as versas a printing problem.
Scanner glass and white scan backing
If you have any of the following symptoms, the scanner glass or white backing may need cleaning:
Black spots or lines appear in copies and/or faxes.
"Replace scanner cover" error message on the front panel display.
Special copy features such as clone do not work correctly
The scanner glass position and size will depend on the product.
Scroll-fed products have a narrow glass strip located under the front panel (see Figure 1) or under the scanner cover (see Figure 2).
Flatbed products have a large scanner glass under the top cover.
Might be worth checking it out.
Old April 13th, 2003, 02:04 PM     #7 (permalink)
draboo's Avatar
i shall,thanks
Old April 13th, 2003, 04:07 PM     #8 (permalink)
I don't think this is your issue, still looks like a scanner not a printer problem to me, anyhow here's a link that MAY work..
free hp cleaning kit for your hp deskjet 600 and officejet 500, 600 and 700 series printer:
Eliminates black ink streaks
Maintains clear, sharp text
Fast and easy
There are two cleaning kits in circulation. Below are descriptions of each:
C6597AM - The original Cleaning Kit came with a CD and five template sheets with cleaning strips attached. This kit is not compatible with the HP Deskjet 610, 630, or 640C series printers.
C8717AM - The newer Cleaning Kit comes with a CD and six cleaning strips. The Cleaning Kit must be used to print the templates.
http://hpcleankit.bgt.com/Cleankit.jsp?Lang=all
Old April 14th, 2003, 01:11 AM     #9 (permalink)
Ordained Mommy
NeoStarO1's Avatar
Hi Doc,
I had found that one too But.......................... look at this quote. So really depends on his OS.
order a free hp cleaning kit for your hp deskjet 600 and officejet 500, 600 and 700 series printer:
Fast and easy
*Microsoft Windows NT, Windows 98, Windows 95, Windows 3.1
For other operating systems, please use manual cleaning procedures at www.hp.com/support/cleanprint
Im not sure how this one would work as his printer model isn't listed. v40
Also why do they make the kits if it doesn't support 2000/ME/XP?
Old April 14th, 2003, 03:54 AM     #10 (permalink)
cadetstimp's Avatar
I've found this site to be invaluable for practile printer info and parts...
http://www.fixyourownprinter.com/
cadetstimp is offline   Reply With Quote
Is It Just Me? (1635)
Review My Build (6)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
boot from CD-ROM in chipset via P4M80.. (0)
Review My Build (6)
windows 7 retail and rtm (1)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
