X Dreamer Case Temp Display
Currently Active Users: 2429
Discussions: 200,515, Posts: 2,374,463, Members: 245,839
Old May 10th, 2003, 06:28 PM   Digg it!   #1 (permalink)
RayH's Avatar
I just purchased an X Dreamer Case w/built in backlit temp display. I can see how the back lighting works. Does anyone know how the temp indicator works? It has a flat probe that I stick to something. How would I connect it to a P-4?
TheGreatRaymond@sbcglobal.net
Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
RayH is offline   Reply With Quote
Old May 10th, 2003, 07:25 PM     #2 (permalink)
depends if you want cpu or case temp
on a random note how do you like the case? ive been looking at maybe getting one so 1st hand experiance would be good
cbuddha42 is offline   Reply With Quote
Old May 10th, 2003, 08:02 PM     #3 (permalink)
vserlnv's Avatar
I just got mine back. Gave it to a guy at work for him to bore out the holes for the fans. Comes with perforations that are really kind of small and I figured they would disrupt the airflow in the case a lot.
So anywhoos, now they are wide-freaking open. Gonna put in 2 Sunon 50CFM 80mm(s) in the back, and 2 in the front as well as 2 80mm Blue LED fans ( there is 4 fan mounts in the front - woohoo! )
One thing I noticed is the PS that came with it seems kind of lame. Yes, it is a 350watter, but it is very lightweight, and I doubt it will do well in an overclocking situation. For now it will do, I'm just going to throw my old KR7A-133 and non-overclocked XP1900+ in there. But eventually I'll be upgrading that power supply.
Cool looking case though.
Guess I'll get around to mounting that probe myself soon. We'll see what's involved then.
Let us know how you did it.
Crunching to Crush Cancer!
Somebody, Stop Me!
Scott
vserlnv is offline   Reply With Quote
Old May 10th, 2003, 09:13 PM     #4 (permalink)
RayH's Avatar
First, it took me some research to figure out what the PROBE actually was. I thought it was some wires that got spliced into somewhere. But apparently, I think I can slip the probe between the P4 CPU and the heatsink.
I bought the case for a computer I'm building my son for his birthday. It seems to be sturdy enough. He won't be clocking the thing, so the power supply will be adequate.
I don't know about running a case wide open. Most computers I've had did OK with it. But I've also built some that needed the case covers on. Without the cover, the venturi got affected.
Anyway, I got the case for $55 at a computer show. It seems to be a good value for the money.
Old May 10th, 2003, 09:23 PM     #5 (permalink)
vserlnv's Avatar
Once I took the front bezel off, I could see the perforations would block ar somewhat.
When I meant wide open, I meant the places where the fans mount to, only. Instead of a perforations there is 80mm wide open holes.
I'll defintely have the sides on and all. Just the air will flow through the fans much more freely.
Think I got mine for right around that ( $$ ) online, perhaps $57.99. Got the cobalt blue one.
Agreed, definitely a good value.
Old May 11th, 2003, 04:23 PM     #6 (permalink)
RayH's Avatar
vserlnv: Where did you mount the probe?
Is It Just Me? (1649)
windows 7 retail and rtm (5)
HELP!!! What do you think of this s.. (24)
Review My Build (6)
Assosiations (21503)
My 1st pc build (40)
Aero in Vista (7)
nvidia geforce 9500GT 1gig DDR2 (0)
HELP!!! What do you think of this sys.. (24)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
