Packard Bell manual
Currently Active Users: 2041
Discussions: 200,919, Posts: 2,379,071, Members: 246,287
Old May 20th, 2003, 05:51 PM   Digg it!   #1 (permalink)
DoctorReno's Avatar
Packard Bell manual
I have a friend with a older Packard Bell. We downloaded what we hope to be the correct manual from PriorityOneSupport.com. The file comes as a self extractin zip. It extracted and ran and opened up what I think is a DOS window on my monitor. It has the message C:\DOCUME~1\student\LOCALS~1\temp\WZS79.tmp> followed by a flashing horizontal cursor.
Does anyone know what I am supposed to do here? I believe it is supposed to put the manual in the program list accessed by the Start button but nothing is there.
The OS on my machine is XP pro.
DoctorReno is offline   Reply With Quote
Old May 20th, 2003, 06:16 PM     #2 (permalink)
crazyray's Avatar
As I recall, you need to download "viewer.exe" from Priority One and install it on the machine. You should then be able to view the file (manual) you downloaded.
The viewer is located at the top of the list of downloadable Packard Bell files in the drivers - Packard Bell area at Priority One.
Hope my memory is correct.
crazyray is offline   Reply With Quote
Old May 20th, 2003, 06:36 PM     #3 (permalink)
Mean Moderator
EvilRick's Avatar
What model of Packard Bell is it?
Did you check here to see if they have the manual as well.
EvilRick is offline   Reply With Quote
Old May 21st, 2003, 02:47 PM     #4 (permalink)
DoctorReno's Avatar
I left my information at home today so I don't recall the exact PB model # of this unit but I believe the MoBo is the 600.
Thanks for the tip on needing Viewer.exe crazyray but it won't run on XP. I get the error that it cannot run a 16 bit program.
If you can't say something nice... SAY IT REALLY LOUD!!
Old May 21st, 2003, 10:23 PM     #5 (permalink)
Leader of the Crab People
Redwolf's Avatar
Send a message via ICQ to Redwolf Send a message via AIM to Redwolf Send a message via Yahoo to Redwolf
Right click the file and choose properties. Somewhere in the menu will be an 'emulation' section. Turn it on and choose Windows 95.
Redwolf is offline   Reply With Quote
Old May 21st, 2003, 10:26 PM     #6 (permalink)
DoctorReno's Avatar
K, I will try that tonight. Thanks
Old May 22nd, 2003, 04:35 PM     #7 (permalink)
DoctorReno's Avatar
Redwolf, I tried what you suggested. The viewer.exe seemed to copy the files and install fine. I then went to the manual file, 600.exe, and did the same, (win95 compatability mode) and damned if it didn't hang up and give me the same original message in the DOS box that I described in my initial post. Any ideas why?
Mumble, grumble I may end up having to find an old machine with 95 or 98 on it huh? Issues like this, rare as they are, are maybe a reason to have a machine set up to dual boot.
Is It Just Me? (2850)
Obama the Muslim (13)
Print spooler problem (12)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (33)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
