Join TechIMO for Free!
Thread Tools
Currently Active Users: 2111
Discussions: 186,677, Posts: 2,227,832, Members: 230,321
Old June 4th, 2003, 10:09 PM   Digg it!   #1 (permalink)
Want to learn DOS. Where do I start?
Any good websites you could reccomend or downloadable software/freeware would be very helpful
Computer is offline   Reply With Quote
FREE instant scan
Old June 4th, 2003, 10:15 PM     #2 (permalink)
What exactly do you want to learn?
If you're learning for command line utilities for 2k/XP thats something different than 'learning DOS'
(NT/2k/XP is not DOS)
vass0922 is online now   Reply With Quote
Old June 4th, 2003, 10:25 PM     #3 (permalink)
I am using 98. Sorry if I confused you. I really dont know anything. I want to learn the different commands so I can access files other stuff. What is "learning DOS". DOS is just an OS with no graphic interface right? I hope so. Thanks
Old June 4th, 2003, 10:46 PM     #4 (permalink)
I always loved DOS. It did exacly what you told it to do, didn't hog resources and never crashed. Those were the days. Hope I never see them again though.
Do a google search on DOS Commands and you'll get quite a few hits and a couple of walk throughs to get you going.
If you need a real copy of MS DOS, I could probably scare up a couple of disks for ya. Think I still have 4.0, 5.something, 6.0 and 6.2.
travis4prez is offline   Reply With Quote
Old June 4th, 2003, 10:54 PM     #5 (permalink)
DoctorReno's Avatar
You might be able to get DOS 6.22 from BootDisk.com
If you can't say something nice... SAY IT REALLY LOUD!!
DoctorReno is offline   Reply With Quote
Old June 5th, 2003, 03:39 AM     #6 (permalink)
youngqd is offline   Reply With Quote
Old June 5th, 2003, 03:45 AM     #7 (permalink)
joker_927's Avatar
I have a 500 page book here with the word DOS on the front. What a novelty item.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | EVGA 7800GT (500/1200) | Tagan 480w
joker_927 is offline   Reply With Quote
Old June 5th, 2003, 01:47 PM     #8 (permalink)
Indispensable Member
surreal's Avatar
Send a message via ICQ to surreal Send a message via AIM to surreal Send a message via Yahoo to surreal
boot to a dos prompt and type /help
(come on guys give me a hand it's been a while )
Help commands<<<<oops I didn't look at youngqd's link
other stuff
surreal is offline   Reply With Quote
Old June 5th, 2003, 01:51 PM     #9 (permalink)
Leader of the Crab People
Redwolf's Avatar
Send a message via ICQ to Redwolf Send a message via AIM to Redwolf Send a message via Yahoo to Redwolf
Okay, you need to get olddos.exe form mocrosft. Hold up while I search for it.
http://www.undercoverdesign.com/dosg...um/mesg/56.htm
Put the program in a new directory and run it. It'l extract files (say yes when it asks). Now the newly extracted help.com file. Press Alt+Enter to go from small to full screen. Have fun reading.
It doesn't explain the basics of DOS, so I will. It's pretty easy, really.
You have the [rompt. It's usually somethign like:
C:\>
This can be changed but that's usually what it is.
You press enter after every line. This executes the command.
As you probably know, windows sets up in a system of drives, files, and directories. Like, oh:
Drives:
Would be like A:, B:, C:, so on. To switch to a drive, just type the drive letter with a colon afterwards.
C:\>A:_ <return>
A:\>_
(NOTE: A: is a floppy drive. Drives have to be accessed. So if there is no floppy in A:, you can't use it.)
To change directories, use 'cd' -quotes. Like:
C:\>cd windows_ <return>
C:\WINDOWS>_
Always put a space after a command. The command, in this case, is 'cd'.
If you want to go to another directory, starting from the C: drive, do this:
C:\WINDOWS>cd \
C:\>_
or something like
C:\WINDOWS>cd \MYDOCU~1
C:\My Documents>_
To go to a subdirectory from where you are now, don't put the backslash. Like:
C:\WINDOWS>cd system
C:\WINDOWS\SYSTEM>_
To go up a directory, use two periods. Like:
C:\WINDOWS\SYSTEM>cd ..
C:\WINDOWS>
Now, time dor a more complex command. The dir command.
The dir command let's you 'see' what's in a directory. Use it as such:
C:\>dir
You may notice that there is so much, it goes past the screen. A quick remedy is the /p switch.
Switches or options are little things you tack on at the beginning of the command that affect how the command operates. Now try this:
C:\>dir /p
Much better, eh?
Another command is the /w command. Try this:
C:\>dir /w
Now cd into your windows\system directory.
C:\WINDOWS\SYSTEM>
Ok, now try this:
C:\WINDOWS\SYSTEM>dir /w
It's too big, eh? Well, we can combine switches. Try this:
C:\WINDOWS\SYSTEM>dir /w /p
Much better.
Lets say you want to see what's in another directory, but you dont' want to chnage directories. Do it like this:
C:\WINDOWS\SYSTEM>dir c:\mydocu~1
or
C:\WINDOWS\SYSTEM>dir ..
Now add switches.
C:\WINDOWS\SYSTEM>dir /p /w ..
very good.
I'll add more later.
Redwolf is offline   Reply With Quote
Old June 5th, 2003, 01:53 PM     #10 (permalink)
surreal's Avatar
thanks Redwolf, you'd think on a nerd site this thread would have gotten 50 replys!
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (664)
Best Boot Drive Imaging Software (9)
Bought an AGP "HIS Radeon HD 3.. (18)
Video card compatability. (7)
File associations (5)
Outlook add-in won't remove. (10)
Is this a good laptop for gamming? (6)
Misery Loves Company... (1873)
Presario Help (6)
[Help] Computer Freeze (4)
Putting together my wish list (21)
Acer SA80 Upgrade (2)
Best Boot Drive Imaging Softwar.. (9)
Computer won't start (10)
Fallout 3 problem (2)
Move folders from desktop to My.. (2)
graphics card driver issue (1)
What graphics card range for q9.. (1)
Seald copy of windows 95 for sa.. (1)
