Thread: Fan controller
June 10th, 2003, 11:25 AM #1
Fan controller
I have (will have soon) 5 80mm x 25mm fans in my chieftec case. 4 of them are rated at 36 cfm @ 3000 rpm, the other one came with the case and I have no idea what its specs are. Do I need to get a fan controller? If so which one do you recommend?
EDIT:
The 4 fans that I bought are 32 dba rated as well.Last edited by jch216; June 10th, 2003 at 11:27 AM.
June 10th, 2003, 11:32 AM #2
Well, i have the same case, and same amount of fans... but they are all adjust their speed automaticaly...
But unless you want full controll over the fans then get the fan controller...
June 10th, 2003, 11:40 AM #3
I didn't order "smart fans". I don't think they will adjust.
June 10th, 2003, 11:41 AM #4
Thes two are pretty good ...and good-n-pretty!
http://www.svcompucycle.com/nexfancon.html
http://www.bestbyte.net/Product.cfm?...Keyword=%23139
June 10th, 2003, 01:42 PM #5
I like this one....
http://www.sidewindercomputers.com/enucbl5fanco.html
I would say to scrap it and start again, without even looking at it. Time to get a local web designer to throw a few ideas at the boss, and see what you really need from a website.
Need website advice
