Windows Problem :: Boot Up Problem :: Please Help!
Currently Active Users: 2318
Discussions: 200,942, Posts: 2,379,296, Members: 246,305
Old June 10th, 2003, 11:39 PM   Digg it!   #1 (permalink)
Hi guys!
Currently here's my set up
13.5 x FSB140 = 1890MHz
Silicon Iamge (RAID 0) - 2 x 30.0GB Maxtor ATA133
Here's my situation..i did run 3DMark2001SE on yesterday..leaving my computer switched on the whole night cause i thought i won't sleep..but in the end i slept and the computer was switched on the whole night..
Woke up this morning, check my CPU temperature - 46C.. then run another benchmark again while i was in toilet..
Came out from toilet, restart my com, the windows load fine..then shut down my computer.. switch it on back, cannot switch on..the com run for a while (about 2 second)..then automatically shut down(this will happened to my com if i overclocked it too much)
Wait for a while..then switch it on back..the com will boot and it brought me into Bios Safe Mode..change the CPU FSB to 13.5 x 140FSB again..restart the computer..and it booted(so i guess there's nothing wrong with my CPU and mobo)
Then i got Windows Error msg..can't even boot to Windows..it says blah blah blah/volume/boot <--something like that cause i have forgotten what's the actualy error) but it is blue screen..
Since i'm running RAID 0, i think should be the array conflict or bad sector? i'm not very sure about my HDD..
1) Is that something wrong with my HDD
2) Is that something wrong with my CPU or Mobo?
Any help would be appreciate. Thanks!
ConquerorX is offline   Reply With Quote
Old June 10th, 2003, 11:57 PM     #2 (permalink)
eweruk's Avatar
Send a message via ICQ to eweruk Send a message via AIM to eweruk
We are going to need to know the blah blah part to help.
eweruk is offline   Reply With Quote
Old June 11th, 2003, 12:14 AM     #3 (permalink)
Sorry for that. I'll post the problem up once i reached home tonight.. Because i really not sure what's the problem. Either is my HDD or my RAID Card Silicon Image..
Old June 11th, 2003, 05:15 PM     #4 (permalink)
Send a message via Yahoo to georgepr
You might be getting a blue screen with unmountable Boot volume.
Fix for this.
Use the recovery console boot into the C: prompt and use this command.
chkdsk /r .It will take some time to check the boot records.Once you complete this boot back normally.Ideally this should work for you.If this work don't forget to run the WinXp Sp1 using windows update.
Regds,
george
georgepr is offline   Reply With Quote
Old June 11th, 2003, 10:14 PM     #5 (permalink)
Thanks.. and yes..
That's the error i got..
Thanks a lot..
The disrespect of Obama by Russian .. (5)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
