Gateway Monitor gives no signal message
Currently Active Users: 1544
Discussions: 200,953, Posts: 2,379,485, Members: 246,324
Old June 15th, 2003, 12:55 PM   Digg it!   #1 (permalink)
Pump you sucker! Pump!
Chuckiechan's Avatar
I have a Gateway "Teleocity" Trinitron 21" monitor I got used.
I can still return it, but I like it!
MY problem is that a message pops up in the screen saying "No video input" and it flashes between channel one and two. When I move my mouse it disappears and all is normal. The screen is being generated by the monitor, almost if the video cable is unpluged, but the cable is fine.
Ideas? Or should I just return it?
Thanks in advance..
Obama has taken America from purported bully to notorious chump in less than a year.
Chuckiechan is offline   Reply With Quote
Old June 15th, 2003, 02:43 PM     #2 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
I would return it. It sounds like some dodgy connection either on the PCB or cable, and that is hassle you could do without later.
IMO its not worth the hassle, but its up to you. Expect more problems in the future if you keep it.
_____
NuKeS
nukes is offline   Reply With Quote
Old June 15th, 2003, 02:49 PM     #3 (permalink)
Training for Bankai
JPMiller's Avatar
replace cable ....make sure no pins are bent...make sure all connections are solid...update video card drivers.... make sure cable is well connected to video card...blow out connectors.
If you return it it will cost you shipping if nothing else so make sure you have covered all your bases.
are you sure your power settings are correct?
is the computer going into standby or sleep and your monitor is thinking it lost signal?
Old June 15th, 2003, 04:51 PM     #4 (permalink)
I bought it locally, so I can just schlep it back...Which is what I think I am going to do.
I'm going to put another cable on it just to try.
It does go to stand by, but my other monitor didn't do the screen thing
thanks...
Is It Just Me? (2944)
Print spooler problem (15)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
