Join TechIMO for Free!
Topic: I had Poproxy.exe error with my Outlookexpress and NAV. I found the fix for it, but along the way I downloaded a IE update. Now, whenever I use my scroll wheel, this noise occurs thru my speakers. I don't know if the p...
Thread Tools
Currently Active Users: 1676
Discussions: 186,606, Posts: 2,223,647, Members: 229,743
Old June 17th, 2003, 07:12 PM   Digg it!   #1 (permalink)
Tarp2's Avatar
Squeaky mouse scroll
Now, whenever I use my scroll wheel, this noise occurs thru my speakers. I don't know if the patch had anything to do with it, and I have heard it before. But, now its all the time. Very annoying.
Anybody know how to turn it off?
Intellimouse explorer
Win2k
IE 6
Thx
Tarp
Tarp2 is offline   Reply With Quote
Old June 17th, 2003, 07:17 PM     #2 (permalink)
ᅟᅠ
OuTpaTienT's Avatar
Check you level controls for your sound card outputs. If anything level not being used is turned up, especially the microphone, then often other activities in the machine can cause feedback. Turn unused levels down or mute them.
OIC 0utpatient.com
OuTpaTienT is offline   Reply With Quote
Old June 17th, 2003, 07:28 PM     #3 (permalink)
Tarp2's Avatar
Thx,
I tried that, but no go.
It almost sounds like it is supposed to be there, as an option to let you know you are scrolling.
I should have mentioned that when I heard it before it was only on certain web sites.
Old June 17th, 2003, 07:32 PM     #4 (permalink)
ᅟᅠ
OuTpaTienT's Avatar
Wow. That's annoying. Have you looked in the the sounds section in the control panel? If it is an assigned sound that's supposed to be there then it's most likely going to be listed there.
Old June 17th, 2003, 07:44 PM     #5 (permalink)
Tarp2's Avatar
Yeah its annoying. Especially if I didnt ask for it.
I've discovered a seperate sound attatched to my start button, so you are right it is an assigned sound. I just have to find it. I checked the control panel sound assignments, nothing there,
I am starting to suspect Norton update, because they were the initial problem.
Hmmm.
Tarp
Old June 17th, 2003, 08:28 PM     #6 (permalink)
its happened on all my computers only if I turn my volume up really high. Must be my crappy speakers, because I have an Audigy 2.
dauss is offline   Reply With Quote
Old June 18th, 2003, 09:05 AM     #7 (permalink)
Tarp2's Avatar
OuTpaTienT,
We were both right. It was an assigned sound, I missed it first time. My fault.
Norton created sounds and put them in my assigned list.
Why would they think I wanted it?
Thx alot
Tarp
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (16873)
Suit forces eHarmony to offer gay d.. (47)
Popular Online Pc Retailers (12)
Super folding (14)
Official World of Warcraft Thread!! (4504)
Folderchat Weekday thread (368)
PSU recommendation, think mines is .. (14)
Suggestions for upgrading graphics .. (12)
Building First Computer need help (24)
Samsung launches 256GB SSD (1)
Dell USB problem (2)
Flashing power LED (1)
PC Wont Perform POST (1)
WEB Video (1)
Win XP "mystery" file.. (1)
have a confusion (1)
please check this out!! (3)
Moving Ghost server to a new ma.. (6)
Woot-off (5)
9800GTX 512meg (8)
Newegg Deals w/free shipping (7)
