Mp3 encoding
Currently Active Users: 1908
Discussions: 200,992, Posts: 2,379,900, Members: 246,360
Old June 18th, 2003, 03:18 AM   Digg it!   #1 (permalink)
joker_927's Avatar
Mp3 encoding
I'm doing some stuff that requires me to encode audio. I have no clue what some of the other selections are, but I know mp3 is very good quality for how small the file size is. The problem is that I don't get a lot of options from the encoding options window. I don't get the higher bitrates that I want. I get like 18kbits/s, 11,025 Hz, Mono 2kb/s. I want the 48kHz and the 128bit rate.
I THINK I need to download an encoder codec. (If im right) Where would I get a good one, preferably free.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
joker_927 is offline   Reply With Quote
Old June 18th, 2003, 03:27 AM     #2 (permalink)
Retired mostly.
That's the integrated codec, it doesn't allow high quality encoding.
Get bladeenc or something.
http://bladeenc.mp3.no/
-M
Old June 18th, 2003, 03:37 AM     #3 (permalink)
Telexen's Avatar
http://www.lame.org/
LAME is the best MP3 encoder you can get...it's only an encoder though...download a program like Exact Audio Copy to use with it to extract the files from a CD.
http://www.exactaudiocopy.de/
Telexen is offline   Reply With Quote
Old June 18th, 2003, 03:45 AM     #4 (permalink)
joker_927's Avatar
http://www.mp3dev.org/mp3/
This LAME download site doesn't work. It just sits there.
Is this is the same thing?
http://download.com.com/3000-2140-10...ml?tag=lst-0-1
Old June 18th, 2003, 03:58 AM     #5 (permalink)
joker_927's Avatar
Ok, I REALLY can't find anywhere to download LAME. All I see is open source tar.gz files.
Any help? I figured since it is the "best" and "quickest" it should be a tad easier to find.
Old June 18th, 2003, 07:52 AM     #6 (permalink)
radio1_mike's Avatar
Send a message via ICQ to radio1_mike
Hi.
I use CDex to encode mp3s and rip CDs. It's a great program and free. You can throw the LAME encoder in it, if you like.
Start here:
CDex
If the program interests you, then go here:
Guide to CDex
The second link contains a special version of CDex with the LAME encoder/some tweaks in it and a web guide on how to use the program all the way from encoding to titles and playlists. If it were me (and I did do this), I'd just start with the second link, download all the stuff, read the guide and start ripping/encoding.
I have used CDex for 2-3 years and that guide is easiest I've seen. The CDex website also has a good forum setup, if you want to read about the nitty gritties like, which beta of LAME encodes best.
Hope this helps.
New Dad since 07/06/2005
radio1_mike is offline   Reply With Quote
Old June 18th, 2003, 12:02 PM     #7 (permalink)
HfdWolfPack's Avatar
HfdWolfPack is offline   Reply With Quote
Old June 18th, 2003, 12:06 PM     #8 (permalink)
omalleytrading's Avatar
I agree with Telexen. Go with LAME and Exact Audio Copy. Great combination!
omalleytrading is offline   Reply With Quote
Old June 18th, 2003, 04:41 PM     #9 (permalink)
Telexen's Avatar
LAME's site sucks so it's hard to find where to download it.
http://www.jthz.com/%7Elame/
Try there.
Old June 18th, 2003, 06:48 PM     #10 (permalink)
consumertalks's Avatar
Originally posted by radio1_mike
Start here:
CDex
I agree with radio1_mike 200%. I rip and encode tons of audio, this program is great. I couldn't believe it was free! The only weird thing is you have to figure out how to set up the folders for the audio you rip.. so read the help section, and change the default settings to suit your needs.
You can choose what bitrate to encode the mp3 depending on what's important for your project (sound quality, file size, both).
Any more questions about this just reply here or pm me, digital audio stuff is what I do.
consumertalks is offline   Reply With Quote
Is It Just Me? (3083)
Health Care Rationing (13)
Delete an OS (17)
Nvidia GTX 260 problem (10)
[F@H SPAM 11/16/09] ! 1/2 months to.. (40)
Internet Lost (5)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (40)
Foxconn Blackops x48 MoBo (3)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
