Thread: Convert DVD to MPEG or .MOV?
July 13th, 2003, 08:44 PM #1
How do I convert a DVD to MPEG or .mov files? Is there freeware or shareware that will do this?
Thanks,
RADAR
July 13th, 2003, 08:46 PM #2
for that you need rip programs there are a lot of free programs but most of them are slow, i bought one and it's pretty good: "Jack the Ripper"
check out www.download.com maybe you find something...
CreaturesCanon EOS 550D | Tamron 18 - 270mm 1:3.5 - 6.3 | Lensbaby Scout (Soft Focus Optic, Fisheye Optic) | Canon Speedlite 430EX II
July 13th, 2003, 08:48 PM #3
I find doom9.net is a good source for information. Check it out.
The difficulty is to try and teach the multitude that something can be true and untrue at the same time. -- Arthur Schopenhauer
July 13th, 2003, 08:59 PM #4
don't forget www.vcdhelp.com
July 13th, 2003, 09:20 PM #5Ultimate Member
- Apr 2003
- 2,083
is there a way u can just burn Divx Files straight with out converting, cause its a real big pain, takes like 10 hours
Athlon 64 3400+ (22-28*C)
ECS 755-A2 1.1B Bios
40GB & 80GB Internal HDD
160GB External HDD
Corsair 2GB PC3200 RAM
ATI AIW Radeon 9600 128MB 8X
July 13th, 2003, 09:27 PM #6I don't know. But don't threadcrap. Start a new thread with your question.is there a way u can just burn Divx Files straight with out converting, cause its a real big pain, takes like 10 hoursThe difficulty is to try and teach the multitude that something can be true and untrue at the same time. -- Arthur Schopenhauer
July 14th, 2003, 08:13 AM #7
You can convert DVDs to MPEG or AVI files using DVDx.
http://www.labdv.com/dvdx/
DVDx is the fastest and easiest solution I've found to converting DVDs to MPEGs or AVIs.
BTW, if you are converting to AVI remember to use some sort of compression codec. (Ex. DivX)
July 14th, 2003, 11:18 AM #8shahaniGuest
You can also use any of the shareware/freeware dvd rippers available all over. Do a search on google for DVD Ripper and you'll get some nice links.
(PS-Sorry for abrupt end to yesterday's call. I think your phone had a lot of static.)
July 15th, 2003, 07:08 PM #9shahaniGuest
If you want to copy a DVD movie to a regular CD, here's a link to download an utility free.
Of ocurse, there will be some loss of quality since output will be an avi file.
July 15th, 2003, 07:48 PM #10Ultimate Member
- Apr 2003
- 2,083
you can use TMPGEnc.
heres the instructions on how to do so with TMP
http://www.dvdrhelp.com/tmpgencdvd.htmAthlon 64 3400+ (22-28*C)
160GB External HDD
no problem. With mine, 560 Ti's in SLI, I don't get much GPU usage with internet, they'll heat up to maybe 40-45C, 50 if the room is warm, with GPU acceleration in the browser. otherwise mine...
SLI problem? :(
