Help With NTFS Permissions
Currently Active Users: 2683
Discussions: 200,965, Posts: 2,379,623, Members: 246,332
Old August 13th, 2003, 03:24 PM   Digg it!   #1 (permalink)
PeterGriffin's Avatar
How can I reset ALL the permissions under the security tab on an entire drive?
Somewhere somehow, things got ALL screwed up. I have MULTIPLE folders within folders and files in all those folders. I want to reset all the permission to ALL files and folders. At this time I want "everyone" to have "full control" on all file and folders and a particular drive.
What do I do?
PeterGriffin is offline   Reply With Quote
Old August 13th, 2003, 03:29 PM     #2 (permalink)
A hero in training
GroundZero3's Avatar
right click on your c drive
then click sharing and secuirty
then click on everyone. and click allow full control
GroundZero3 is offline   Reply With Quote
Old August 13th, 2003, 03:45 PM     #3 (permalink)
Yes, but how do I get that to apply to EVERYTHING else (files & folders) that is below the root of c:\ ?
Old August 13th, 2003, 03:52 PM     #4 (permalink)
Mean Moderator
EvilRick's Avatar
Just eliminate everything but the "Default share". This should put you back to "the way it was before".
Get there by how GZ3 said, right-click, 'Sharing and security', 'Sharing' tab.
EvilRick is offline   Reply With Quote
Old August 13th, 2003, 04:26 PM     #5 (permalink)
Here is what I am looking at.
When I go to the properties of the c: drive this is what I get:
Now, when I go to the security tab, this is what I get:
Now, I go to the advanced button at the bottom and this is what I get:
Do I check the little box at the bottom of this window so that it resets all the folders and files?
PLEASE HELP!!!!
Old August 13th, 2003, 04:28 PM     #6 (permalink)
meese's Avatar
Scratch that. No leave it unchecked.
I'm sorry. The answer is YES. This will transfer the permissions to all subfolders.
meese is offline   Reply With Quote
Old August 14th, 2003, 01:24 AM     #7 (permalink)
**confused**
Okay, I do or don't check the box?
Old August 14th, 2003, 06:30 AM     #8 (permalink)
Front242's Avatar
Any subfolders under drive C will be shared if you check the box.
**warning** Anyone can access any folder on your HD if they get access to your computer either directly or remotely
I recomend that you take the time to do each folder that only you want to access yourself with an administrative share. I do not recomend you ever share your HD. It takes some extra work but it is worth it if you share your computer.
I get all my News from FNC and right blogs, so I know I am fair and balanced.
Front242 is offline   Reply With Quote
Is It Just Me? (3006)
Forty-six years ago today (6)
Internet Lost (5)
windows vista security holes (14)
Open With ..... Win7 (2)
Internet Lost (5)
Help getting around port 80 for camer.. (3)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
