Major problem!
Currently Active Users: 2389
Discussions: 200,941, Posts: 2,379,279, Members: 246,304
Old August 23rd, 2003, 01:25 PM   Digg it!   #1 (permalink)
Exclamation
Major problem!
I was just using my computer and decided to clear up some space. I saw the Nforce (or nvidia) audio codecs and decided to delete them thinking they won't affect my soundblaster auidgy 2 since those have different drivers. So it said to restart my computer and I did. It started up saw LanParty logo, Windows XP load screen, and then after that it just goes blackish . I can listen to windows starting up through my headphones but I can't see anything! I don't think unistalling audio codes would have caused this. Please help soon! I've tryed starting up a lot of times no luck.
Rand Dusing is offline   Reply With Quote
Old August 23rd, 2003, 01:29 PM     #2 (permalink)
jmebonner's Avatar
Go into safe mode by hitting F8 during the startup screen and see if you can run system recovery or reinstall the drivers from there
jmebonner is offline   Reply With Quote
Old August 23rd, 2003, 01:36 PM     #3 (permalink)
Now it is automatically bringing a screen asking you to start in various modes. I pressed safe mod, and a list of drivers came up. but then it "froze"
Old August 23rd, 2003, 01:49 PM     #4 (permalink)
OK, I installed my new sound card to see if that was part of the problem and then restarted in Safe Mode Command Prompt it loads up but then quits reading the hard drive when It gets to mup.sys and just "freezes" up. Sounds like something may be wrong with the hard drive or bad file. Is mup.sys part of Windows XP maybe I should try to Repair it.
Old August 23rd, 2003, 01:54 PM     #5 (permalink)
NDC
Xtreme Member
Send a message via AIM to NDC Send a message via Yahoo to NDC
I believe it is one of Windows XP files...
[NDC]
NDC is offline   Reply With Quote
Old August 23rd, 2003, 02:13 PM     #6 (permalink)
I looked a some similar problems and I'm trying to repair Windows XP now.
Old August 23rd, 2003, 02:15 PM     #7 (permalink)
I'm not exactly sure how to Repair windows XP but it i install it will it delete all my current applcations and games?
Old August 23rd, 2003, 02:18 PM     #8 (permalink)
NDC
Xtreme Member
Repair will not cause you to re-install applications.
Old August 23rd, 2003, 02:25 PM     #9 (permalink)
OK, I tryed using the Recvery Console but then I found the automated repair. Thanks I think this will fix it.
Old August 23rd, 2003, 04:06 PM     #10 (permalink)
.p$YcHo X's Avatar
cool - gj
.p$YcHo X is offline   Reply With Quote
Is It Just Me? (2916)
Wireless Televisions. (9)
Regular Build (6)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
