Results 1 to 3 of 3
    Sep 2003
    Big Rapids US
    2
    Question How did this happen?
    Hi there Guys & Guyettes,
    I'm sure that Angel Cat has told you what a novice I am. Something strange happened a while back; I cannot play Solitaire after I have been on-line without turning the computer off and starting all over again. Also, my mouse has developed a 'hair-trigger'. When I play Solitaire, if I'm not careful, more than one card will turn over at a time. These are not serious problems. They are more of an annoyance than anything but if I can do something to cure it of its bad habits, I would like to know. Can anyone give me some advice?
    Mama-duke
    Senior Member Mead's Avatar
    Nov 2001
    Muskegon, MI
    654
    Which version of windows are you using. Im only assuming you're using windows instead of macos or linux because stuff like that is pretty much par for the course of a windows install. It sounds like corrupt registry entries. I always fixed stuff like that with a fresh install of windows, but im sure someone else will have something else a little less dramatic for you to try first.
    Sep 2003
    Big Rapids US
    2
    Question How did that happen?
    Thanks Mead, that was a quick reply. I have Windows 98. As I said, its more of an annoyance that anything else. CE is my son-in-law and he asked me to bring the computer to him the next time I go down-state for a visit. If its anything that I can't fix myself (which is more than likely) , he will do it, I'm sure. CE and Angel Cat told me what a nice group of people are writing on Techimo and I see that they were right.
    Mama-duke
