Need some NTFS clarification
Currently Active Users: 2481
Discussions: 200,516, Posts: 2,374,466, Members: 245,839
Old October 3rd, 2003, 06:15 PM   Digg it!   #1 (permalink)
Right now I am using win 98. That uses FAT 32 right? I am getting XP soon and that uses NTFS format right? Will this new format effect my harddrive? It is an older HD sortof 30GB 5400rpm. I am not really sure how these formats work anyway. I was planning on reformating my HD when I get XP anyway because it's full of junk. Is there something I must do when I reformat to make it NTFS or does XP do everything for me? Or do I have to worry about getting a new HDD that can support NTFS. Sorry if these questions seem stupid. but I don't really know much about OS formats.
Computer is offline   Reply With Quote
Old October 3rd, 2003, 06:21 PM     #2 (permalink)
A hero in training
GroundZero3's Avatar
win98 uses fat 32 correct
winxp can use either ntfs or fat 32, when formating the drive you have the option to use fat32 or ntfs
make sure if you format to back up what you want to keep, you will not need another hard drive. the one you have will work.
GroundZero3 is offline   Reply With Quote
Old October 3rd, 2003, 06:27 PM     #3 (permalink)
may contain mild peril
SpookyEddy's Avatar
ntfs will give you several benefits including file and folder permissions, indexing, journalling (helps with fault tolerance), quotas and encryption. It also scales better than fat32 in my experience.
As mentioned you can select to use either fat32 or ntfs during the installation of XP.
Regards
ed
I dreamt that a large eagle circled the room three times and then got into bed with me and took all the blankets.
SpookyEddy is offline   Reply With Quote
Old October 3rd, 2003, 06:54 PM     #4 (permalink)
Re: Need some NTFS clarification
The're no STUPID questions. Only dumb mistakes. If you're going to do a clean install. Win XP should do the format and partition.
You just select the comand at the prompt.
Uncle Bob is offline   Reply With Quote
Old October 3rd, 2003, 07:34 PM     #5 (permalink)
excuzzzeme's Avatar
Send a message via AIM to excuzzzeme Send a message via MSN to excuzzzeme Send a message via Yahoo to excuzzzeme
You can "upgrade your system to XP and maintain FAT32 file system. There is no need to re-format the hard drive to NTFS. NTFS is more secure than FAT32 and easier to manage security profiles. "Upgrade" to XP and maintain your 32 on the upgrade (XP will allow you to choose to change file system at install/upgrade). Check your files (programs, misc for integrity) then at your leaisure, open a command prompt and enter:
convert c: /fs:ntfs
you will then convert your files to ntfs. You can convert FROM FAT32 to NTFS. You CANNOT convert from NTFS to FAT32. You can do this without reformatiing your hard drive. Although reccommended I have never backed up files when using this method and never lost files or programs. Have used this on a 110 workstation network. (Call me "Lucky")
Only two defining forces have ever offered to die for you,
Jesus Christ and the American G. I. One died for your soul; The other for your freedom
excuzzzeme is offline   Reply With Quote
Old October 4th, 2003, 02:47 PM     #6 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
yeah, you won't have any trouble. Especially as you want to reformat anyway.
_____
NuKeS
nukes is offline   Reply With Quote
Is It Just Me? (1649)
windows 7 retail and rtm (5)
HELP!!! What do you think of this s.. (24)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
slaving laptop drive (7)
nvidia geforce 9500GT 1gig DDR2 (0)
HELP!!! What do you think of this sys.. (24)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
