!!Desktop Screen disappears!!HELP!!
Currently Active Users: 2070
Discussions: 200,974, Posts: 2,379,792, Members: 246,338
Old October 9th, 2003, 08:33 PM   Digg it!   #1 (permalink)
Exclamation
Hi,
Lately, my desktop and toolbar have been disappearing for like 5 seconds and then reappears but without NAV. This usually happens while Im in the internet ... internet works alright for awhile, but sometimes the screen will freeze up so I press CRTL +ALT+DELETE into Task Manager and it says that Internet Explorer is "not responding", so I will end the program and thats when I get a error log report from explorer asking if I want to send it or not. I never send it. That's when the screen will go blank and reappears a few seconds later without NAV.
I am currently using Windows XP, NAV, and Zone Alarm Pro 4.
I don't know why this is happening!! Could someone tell me if I should be worried?? Could this be a virus?? HELP!!!!
THANKS!!!
Maye is offline   Reply With Quote
Old October 11th, 2003, 01:01 AM     #2 (permalink)
is 4 f00t secks
sixf00t4's Avatar
no need to worry. what is happenning is explorer.exe is closing and restarting. no big deal, happens all the time.
you can disable the error reporting prompt by right clicking on my computer, left click on properties, select the advanced tab, then click on the error reporting button. there you go
Music (4/15/08) - Video (4/15/08) - blog - Legend of Six RPG
sixf00t4 is offline   Reply With Quote
Old October 11th, 2003, 01:08 AM     #3 (permalink)
Where's the beef?
Scott Tiger's Avatar
6'4 is right, your problem is that I.E. is crashing and taking Explorer with it.
Here are two suggestions:
1. Open "My Compter". Click on "Tools" - "Folder Options" - "View" - and check the box that says "Launch folder windows in a seperate process". Then restart your machine. This tweak will make IE and Explorer run seperately so when IE crashes it won't take Explorer with it. The only downside is that your computer will be using slightly more memory. Definitely worth it.
2. Ditch I.E. and get another browser.
Where's Lunch?
Scott Tiger is offline   Reply With Quote
Is It Just Me? (3061)
Charges against non-tippers dropped.. (8)
The disrespect of Obama by Russian .. (49)
Delete an OS (16)
Nvidia GTX 260 problem (8)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
Dynex DX E-402 (3)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
