two operating systems
Currently Active Users: 1289
Discussions: 200,929, Posts: 2,379,149, Members: 246,296
Old October 25th, 2003, 03:19 AM     #11 (permalink)
Im running a dual boot me/xp o.s setup.
Why, I still prefer Win me over xp for most of the things that I do.
Most of my customers are still using me, and for the few that are using xp, I can relate better doing phone support with it in front of me.
At one point I had a triple boot with 98se,me, and xp, but dropped 98 for lack of intrest.
My setup with 177gb of hd space has a seperate folder for all of the xp related apps, and all of the me apps are isolated as well, that way removing one or the other does not affect functionality.
Works very well for me, and I can also cross test compatibility issues.
GA 7n400pro
XP2600m 12.5x200=2508.
Chaintech 6600 Agp 256mb
WD40,WD80,WD120 and Samsung 200 GB
dafanman is offline   Reply With Quote
Old October 25th, 2003, 03:40 AM     #12 (permalink)
icer-zerocool
Dj-Icer's Avatar
Send a message via ICQ to Dj-Icer Send a message via Yahoo to Dj-Icer Send a message via Skype™ to Dj-Icer
i thought that is what they have in the arcade games; 2 cpu's, mount for devastating performance, focusly on gamings.
Dj-Icer is offline   Reply With Quote
Old October 25th, 2003, 11:47 AM     #13 (permalink)
Supporting our military
Bill in SD, CA's Avatar
I have 98 - 2K.
Some software doesn't run in 2K for me.
2K hates my Officejet but 98 likes it.
Can switch to 98 to help here in support.
Bill
Bill in SD, CA is offline   Reply With Quote
Old October 25th, 2003, 11:53 AM     #14 (permalink)
DanGrease's Avatar
I have both Windows XP Professional and Linux (Redhat) installed on my machine. I have Linux to just learn and 'play around' with it, but also to do the usual stuff as surfing the web, checking e-mails, listen to music. And Windows I use for the rest such as playing games. I dont see though the advantages of having both Windows ME and Windows XP, and personally I would recommend you to stay away from Windows ME. If you use it for playing DOS Games, get Windows 98 instead
dan
DanGrease is offline   Reply With Quote
Old October 31st, 2003, 04:34 AM     #15 (permalink)
Brondum9's Avatar
Send a message via ICQ to Brondum9
Good way to learn linux
Brondum9 is offline   Reply With Quote
Old October 31st, 2003, 04:42 AM     #16 (permalink)
bailey's Avatar
1. W98se and W2k
2. xp and red hat 9.0
3, W98se and xp
4. laptop xp-home
5. laptop W3.11
6. laptop W95
I never had ME and never will
bailey is offline   Reply With Quote
Old October 31st, 2003, 11:40 AM     #17 (permalink)
If anyone is intrested, here is a link to a mutli booting how to:
http://www.flickerdown.com/stewks/ar...p?articleId=27
For all that are so down on win me, I dont get it, its no better or worse than any other o.s, all have their share of short commings.
Having worked on thousands of systems over the last 10+ years, and having been involved with windows o.s since win 95 beta, Ive seen em all.
And from my hands on experience, I would still reccomend win me over 98 and 98se
Is It Just Me? (2869)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
