Hi, I'm using a:
P4 2.8GHz 800MHz FSB, Hyperthreading tech.
Windows XP Pro (legitamate version!)
1 GB Corsair "Extreme" memory (sidenote, stuff is amazing!)
WD 200GB Hard Drive 7200RPM 8MB cache
WC 40GB Hard Drive 7200RPM 8MB Cache (WinXP loaded on this drive)
SB Audigy 2 Soundcard
ATI Radeon 9600 Pro 128MB
DVD-R 2x Toshiba
DVD-ROM Mitsumi 16X
On board Lan Gigabit (intel) 10/100
Linksys WAP 4 port Switch
Cable Modem
I am trying to connect to my internet via the router. I am unable to remove, release, or renew the IP address. I've tried multiple NIC cards and also connecting directly to the cable modem and was unsuccessfull. I've done the newtwork setup wizard and created connections, and it still wont' connect. I am thinking it might be a windows problem? When I try to repair the connection I get the message "Renew IP address failed and flushing ARP cache failed" Any help or input is appreciated.
