router problems  | | |
November 8th, 2003, 12:45 PM
hey,
I have been running apache on my computer for my website and i'm using a linksys router, and i fowarded the http to port 80 and its been working fine, well this morning when i got up i could not access my website so i did a port scan and port 80 was no longer open so i reset my router and redid the fowarding to port 80 and it still isint working, port 80 is not open and i can't access my site, does anyone know what i can do to fix this problem? |
November 8th, 2003, 12:51 PM
| | Free Thinker
Maybe your ISP is blocking port 80 requests?
You can't fix stupidity.
November 8th, 2003, 12:57 PM
would it all of the sudden start doing that? |
November 8th, 2003, 01:02 PM
| | Not Really a Member
quite possibly, especially if you've gotten enough traffic for them to notice.
This on a private line or a business line?
If its a private residential line then yes its quite possible.
They do NOT like you running servers on a residential line
Check your EULA
November 8th, 2003, 02:41 PM
EULA?? its private and i don't think i have gotten much traffic to my site but i still can't get port 80 to open? they shouldn't be able to do that, i'm paying for the service and i should be able to use it as i please, thats just wrong |
November 8th, 2003, 02:47 PM
| | Free Thinker
End User License Agreement
It usually states that you are not allowed to run a server of any kind. They only have so much bandwidth and if too many people are running high traffic servers, then no one is happy.
If you don't mind telling me, what's your website? I'll see from here which ports are open. |
November 8th, 2003, 02:50 PM
i just did a port scan on my ip and it says that no ports are open, i tryed to open up port 20 for an ftp and it don't work either |
November 8th, 2003, 02:51 PM
| | Free Thinker
Which router exactly do you have? If it has a setting for SPI, and you have that enabled, it will block all ports regardless of any port forwarding settings you have. |
November 8th, 2003, 02:52 PM
its a linksys, and my site was working yesterday before i went to bed so i don't know how it would have got enabled and i have reset my router 2 times and redid the fowarding this morning |
November 8th, 2003, 02:54 PM
| | Free Thinker
The other thing you could try is to set your webserver as the DMZ host. That way it'll be outside the firewall and you'll know for sure if it's your router or your ISP blocking the ports. If you set it as the DMZ host and then you can reach it, you have a router setting issue. If you can't reach it when it's the DMZ host, you're probably getting blocked by your ISP. |
